1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: XYgraph pv_name
To: "Kasemir, Kay" <[email protected]>, EPICS Tech-Talk <[email protected]>
Date: Fri, 4 Aug 2017 08:35:44 +0200
Hi Kay
You're a star....working beautifully  on my system now...thanks a million.
Just a small point.. we are not using 'Display Builder' yet as we have loads of CSS opi's running on our new tandetron. As a standard, we decided to use CSS 4.1.0 for now. As Display Builder becomes more used, we'll see to do a upgrade there.
Your 'select.py' script below is interesting and I would like to know (if you have the time) the meaning of:
      (1) macros = widget.getPropertyValue("macros").getCopy()    # cannot find this function
      (2) macros.put("PV", "sim://sine")                                               # I assume here you set the macro to the PV name
      (3) widget.setPropertyValue("macros", macros)                        # and add macro to widget (parent macros?)
Otherwise I'm very pleased and grateful for your assistance and insight
Have a nice weekend
Amien
Cape Town
On 03/08/2017 18:01, Kasemir, Kay wrote:
Hi:
>I have a list of 40 Harps and each Harp has 48 current channels (waveform).
>In our current CSS we physically create a 'tabbed' control with all the 40 harps (one harp per tab). Each tab has a xygraph control.
> So when a user selects a specific harp from the group control, we just make that tab visible etc..
>What I want is only 1 xygraph control that gets the PV name from the 'group' control selected..
I like what you have in mind.
An actual Tabbed Container with 40 tabs, each containing an XYGraph would be a great waste of CPU and memory because all the tab's content is to some degree active, connected to PVs etc.
Better to have 40 selectors which somehow update just one XYGraph.
What you can try is having that XYGraph in an embedded display (Linking Container).
That embedded display somehow receives one of the 40 sets of PVs as macros.
http://ics-web.sns.ornl.gov/kasemir/switch.zip has a related example. Two buttons that write some local 'select' PV, and embedded display (Linking Container) which reacts to that PV by updating the macros of the embedded display with a script:
# Attached to to embedded display (Linking Container)
# pvs[0] PV 0, 1, ... that selects which macros to use
from org.csstudio.opibuilder.scriptUtil import PVUtil
value = PVUtil.getLong(pvs[0])
if value == 0:
else:
    macros.put("PV", "sim://ramp")
widget.setPropertyValue("opi_file", "")
widget.setPropertyValue("opi_file", "embedded.opi")
That example has 2 cases instead of 40, and it only sets one "PV" macro, but you can easily add more.
Note that after changing the macros, it needs to change the "opi_file" to trigger an update of the embedded display (Linking Container).
For what it's worth, the Display Builder, i.e. the update to BOY, has a "Navigation Tabs" widget.
It looks like the Tab widget (which is also available), but each Tab is configured with the name of a display to embed and macros.
At runtime, when you select a tab it loads the display file and macros for that tab, basically what the switch.zip example does.
Compared to the original Tab widget, changing tabs takes a tiny bit longer because it loads the file for that tab, creates the widgets, connects to PVs etc., but on the other hand only the content for one tab is active at a time. Other tabs use zero CPU and memory, which tends to be an overall win.
Kay
Re: XYgraph pv_name Kasemir, Kay
XYgraph pv_name Amien Crombie
Re: XYgraph pv_name Amien Crombie
Prev: Re: XYgraph pv_name Kasemir, Kay
Next: Webopi issue with Text Update widget rule Petrella, Nicoletta
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: XYgraph pv_name Kasemir, Kay
