Subject: Re: Archiver: Problems with disconnected PVs
To: "Shankar, Murali" <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 1 Sep 2017 15:59:26 -0300
Em 01-09-2017 15:10, Shankar, Murali escreveu:
is there another location
Depends on your setup of course but I see something like this in my arch.log right at the beginning.
<context class="com.cosylab.epics.caj.CAJContext">
  <preemptive_callback>true</preemptive_callback>
  <addr_list>gateway:5076 gateway:5077 gateway:5078 other-gateway:5064</addr_list>
  <auto_addr_list>false</auto_addr_list>
  <connection_timeout>30.0</connection_timeout>
  <beacon_period>15.0</beacon_period>
  <repeater_port>5069</repeater_port>
  <server_port>5076</server_port>
  <max_array_bytes>80000000</max_array_bytes>
  <event_dispatcher class="org.epics.archiverappliance.engine.epics.JCAEventDispatcherBasedOnPVName"/>
</context>
I found it:
<context class="com.cosylab.epics.caj.CAJContext"> <preemptive_callback>true</preemptive_callback> <addr_list></addr_list> <auto_addr_list>true</auto_addr_list> <connection_timeout>30.0</connection_timeout> <beacon_period>30.0</beacon_period> <repeater_port>5065</repeater_port> <server_port>5064</server_port> <max_array_bytes>30.0</max_array_bytes> <event_dispatcher class="org.epics.archiverappliance.engine.epics.JCAEventDispatcherBasedOnPVName"/>
</context>
One thing look's strange, max_array_bytes...Looks a bit low, can be the problem?
pause/resume I tried
Pausing/resuming tears down and recreates the CAJ channel for the PV so if you are unable to connect even after this you probably have some misconfiguration; that is, you can rule out most transient errors.
IOC's log on ioc machine right
Yes; sometimes there could be stuck tasks on the IOC side; you can check for that.
Your PV Details page for this PV could have information there that could help. You can get to this using something like so - http://localhost:17665/mgmt/bpl/getPVDetails?pv=Your_PV
I take a look, but i can't see anything strange
Finally, would you be in a position to attempt a restart?
I will try it, but on next week.
The most strange thing is a lot of PV's work well, and a few has problems (eventually disconnect)
Thank you again
Regards
Murali
Sent: Friday, September 1, 2017 10:52 AM
To: Shankar, Murali; [email protected]
Cc: ([email protected])
Em 01-09-2017 13:39, Shankar, Murali escreveu:
This seems like it might be a CA client configuration issue
This is the most likely case. The engine prints out it's CAJ
configuration on startup and you should be able to see this in your logs.
I didn't find it. I find engine/logs/catalina.err, is there another
location?
You can try a couple of things. You can pause/resume the PV's in
question and see if they reconnect back. You can also look in the IOC's
logs and see if there is anything interesting going there.
pause/resume I tried. IOC's log on ioc machine right? apparently there
is no errors (on epics console).
Regards and thank you for the answer
Murali
Gabriel Fedel
Software de Operação das Linhas de Luz
Laboratório Nacional de Luz Síncrotron – (LNLS)
Centro Nacional de Pesquisa em Energia e Materiais (CNPEM)
[email protected] | +55 (19) 3512 1226
www.lnls.cnpem.br
Gabriel Fedel
www.lnls.cnpem.br
Re: Archiver: Problems with disconnected PVs Shankar, Murali
Re: Archiver: Problems with disconnected PVs Gabriel de Souza Fedel
Prev: Re: Archiver: Problems with disconnected PVs Shankar, Murali
Next: Re: Archiver: Problems with disconnected PVs Shankar, Murali
