1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS communication paradigm
To: renato sanhueza <[email protected]>
Date: Mon, 13 Nov 2017 16:15:44 +0100
Hi Renato,
One reason making it hard to decide which of the common communication paradigms EPICS/CA are based on: EPICS/CA have been designed in the 80s, i.e. years before Distributed Objects (and their communication paradigms) were developed.
If you look at currently commonly used protocols, CA shares a number of properties with OPC UA, in that it offers:
  • Discovery: work transparently across multiple servers on local PCs and/or networks
  • Global address space: all data is found through its unique name
  • On-demand: read and write data/information based on access-permissions
  • Subscriptions: monitor data/information when values change
Hope this helps,
~Ralph
On Sun, Nov 12, 2017 at 1:17 AM, renato sanhueza <[email protected]> wrote:
Hiding things is a common feature associated to a high level of abstraction. Thanks again for your time Mark. I will continue reflecting about this topic with the information you gave me.
On Sat, Nov 11, 2017 at 8:36 PM, Mark Rivers <[email protected]> wrote:
I'm not a computer scientist by any means.  But I think it is fair to say that Channel Access operates at a fairly low level of abstraction.  It deliberately hides the "object" nature of EPICS records.  It only provides access to specific fields in those records.  So there is no capability of introspection of the record structure, etc.
There is a new EPICS protocol called pvAccess, commonly known as EPICS V4.  It provides a much higher level of abstraction, and is designed with middleware services as one of its target applications.  It allows the transmission of arbitrary structured data with full introspection.
Sent: Saturday, November 11, 2017 4:28 PM
To: Mark Rivers
Cc: [email protected]
Hi Mark,
Thanks for your answer. You give a good summary of the whole communication process. I was asking about the communication paradigm as an attempt to determine in which level of abstraction EPICS works.
For example the Message Passing Paradigm is associated with the lowest level of abstraction in distributed inter-process communications. Message Systems Paradigm (aka Message Oriented Middleware) works in a higher level of abstraction than Message Passing, but lower than Distributed Object Paradigm.
EPICS use the Channel Access Protocol to communicate clients and servers, but I couldn't intuitively map this protocol to any of the "common" communication paradigms I know (besides the Distributed Objects Paradigm).
On Sat, Nov 11, 2017 at 6:59 PM, Mark Rivers <[email protected]<mailto:[email protected]>> wrote:
Hi Renato,
What you said is basically correct.   An EPICS control system typically consists of multiple channel access servers located on multiple computers.  There are also multiple channel access clients located on multiple computers.  The clients normally locate EPICS process variables (PVs) on the servers using a UDP broadcast with the PV name, and then connect to them with TCP.  They can then subscribe to callbacks from the servers whenever the PV changes (publish/subscribe model), and can write new values to the PVs.
I'm not sure if this answers your question?
From: [email protected]<mailto:[email protected]nl.gov> <[email protected]<mailto:tech-talk-bounces@aps.anl.gov>> on behalf of renato sanhueza <[email protected]l<mailto:renato.sanhueza@alumnos.usm.cl>>
Sent: Saturday, November 11, 2017 1:05 PM
To: [email protected]<mailto:t[email protected]>
Subject: EPICS communication paradigm
Hi, I am learning about EPICS and I think I understand the basic concepts about it but I am still unable to determine in which communication paradigm is EPICS based on.
My best guess is that EPICS implements the Distributed Object Paradigm because Records are object distributed across different Channel Access Servers. Other technologies which implement this paradigm are CORBA and JavaRMI for example.
I would really appreciate if someone can point me in the right direction.
Thanks in advance
Renato Sanhueza Ulsen
Ing Civil Informática.
EPICS communication paradigm renato sanhueza
Re: EPICS communication paradigm Mark Rivers
Re: EPICS communication paradigm renato sanhueza
Prev: Re: areaDetector and HDF5 file saving segafaults Mark Rivers
Next: Re: EPICS base R3.15.5 special CONFIG and RULE files Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: EPICS communication paradigm renato sanhueza
Next: Fwd: EPICS communication paradigm renato sanhueza
