Note that variable should be spelled $(MSI3_15)
- Andrew
On 11/10/2017 07:53 PM, Bruce Hill wrote:
> Hi Kristi,
> In addition to Ben's suggestions, for R3.15.5, you'll also need to
> change $(MSI) to $(MSI_3_15) in your rules.
> If that doesn't get it working, send me the path to your build top and
> I'll look into it further.
> Cheers,
> - Bruce
> On 11/10/2017 04:38 AM, Benjamin Franksen wrote:
>> [sorry for possible duplicates, forgot to reply to the list]
>> On 11/09/2017 11:59 PM, Luchini, Kristi L. wrote:
>>> However, my RULES file from R3.14.12, now either generate errors
>>> during the build or it will generate an empty alhConfig which it
>>> installs in to $TOP/alh.
>>> Is there an example of a RULES_<file type> that I can used. Below is
>>> what I am using, which clearly is wrong.
>>> File configure/Makefile
>>> CHECK_RELEASE = YES
>>> TARGETS = $(CONFIG_TARGETS)
>>> CONFIGS += $(subst ../,,$(wildcard $(CONFIG_INSTALLS)))
>>> CFG +=CONFIG_ALARMS RULES_ALARMS
>>> CFG +=CONFIG_PROTOS
>>> include $(TOP)/configure/RULES
>>> File: configure/CONFIG_ALARMS
>>> FILE_TYPE+=ALHS
>>> INSTALL_ALHS = $(INSTALL_LOCATION)/alh
>> This is no longer needed as there are now a similar definitions in base,
>> which use ALH, not ALHS. You can keep you won FILE_TYPE, though, since
>> due to the different name there is no conflict.
>>> File: configure/RULES_ALARMS --- similar to R3.14.12 RULES.Db
>> This is a mistake. RULES.Db is an overly complicated monster. I wish
>> there was a way to completely disable it.
>> All you need is the vpaths:
>>> vpath %.alhConfig $(USR_VPATH) $(GENERIC_SRC_DIRS) $(dir $(ALH))
>>> vpath %.alhsubstitutions $(USR_VPATH) $(GENERIC_SRC_DIRS) $(COMMON_DIR)
>> however, these are not good. I would rather use
>> vpath %.alhConfig $(USR_VPATH) $(GENERIC_SRC_DIRS) $(COMMON_DIR)
>> (Presumably alhsubstitutions are sources, while alhConfig may be sources
>> or produced by the rule below.)
>> The only rule you need is
>>> $(COMMON_DIR)/%.alhConfig: %.alhsubstitutions
>>> @echo "Inflating alhConfig from $< using local rule"
>>> @$(RM) $@
>>> @echo "$(MSI) -S$< > $(@F) </dev/null"
>>> @$(MSI) -I.. $(ALHFLAGS) -S$< </dev/null > $@
>> which I would re-write as
>> $(ECHO) "Inflating alhConfig from $< using local rule"
>> $(MSI) -I.. $(ALHFLAGS) -S$< > [email protected]
>> $(MV) [email protected] $@
>> (Why suppress echoing of the command line and then echo manually in a
>> separate command, just so you don't see the $(ALHFLAGS) parameter? The
>> "output to .tmp, then mv" pattern is to make parallel make more
>> reliable.)
>> Also, the include of RULES_ALARMS below
>>> File: Makefile:
>>> TOP=../../..
>>> include $(TOP)/configure/CONFIG
>>> ALHS += ntwk_inj.alhConfig
>>> include $(TOP)/configure/RULES_ALARMS
>> is automatically done by the base rules.
>> Cheers
>> Ben
- RE: EPICS base R3.15.5 special CONFIG and RULE files Luchini, Kristi L.
- Re: EPICS base R3.15.5 special CONFIG and RULE files Benjamin Franksen
- Re: EPICS base R3.15.5 special CONFIG and RULE files Bruce Hill
Re: EPICS communication paradigm Ralph Lange
Fwd: EPICS communication paradigm renato sanhueza
<2017>
2025
2026
<2017>
2025
2026
