Subject: RE: Possible bug in areaDetector/ADSupport/supportApp/nexusSrc/Makefile?
To: Jörn Dreyer <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 20 Nov 2017 18:57:36 +0000
These are now all fixed and pushed to master branch on Github.
Sent: Monday, November 20, 2017 8:50 AM
To: Jörn Dreyer; [email protected]
Subject: Re: Possible bug in areaDetector/ADSupport/supportApp/nexusSrc/Makefile?
Hi Jörn,
Thanks for finding that.  I just did a search of all the Makefiles in areaDetector, looking for lines with the string USR_INCLUDES and without the string -I.  There are actually a number of errors like the one you found.  I will fix these today.
corvette:~/devel/areaDetector>find . -name Makefile -exec grep -H USR_INCLUDES {} \; | grep -v "\-I"
./ADPluginEdge/edgeApp/edgeSrc/Makefile:USR_INCLUDES += $(OPENCV_INCLUDE)
./ADAndor/andorApp/src/Makefile:  USR_INCLUDES += $(XML2_INCLUDE)
./ADADSC/adscApp/src/Makefile:# detcon_state.h.  USR_INCLUDES should include the directories containing
./ADURL/urlApp/src/Makefile:    USR_INCLUDES += $(GRAPHICSMAGICK_INCLUDE)
./ADSupport/supportApp/hdf5Src/Makefile:        USR_INCLUDES += $(SZIP_INCLUDE)
./ADSupport/supportApp/hdf5Src/Makefile:        USR_INCLUDES += $(ZLIB_INCLUDE)
./ADSupport/supportApp/hdf5Src/Makefile:          USR_INCLUDES += $(BLOSC_INCLUDE)
./ADSupport/supportApp/nexusSrc/Makefile:        USR_INCLUDES += $(HDF5_INCLUDE)
./ADSupport/supportApp/nexusSrc/Makefile:        USR_INCLUDES += $(SZIP_INCLUDE)
./ADSupport/supportApp/nexusSrc/Makefile:        USR_INCLUDES += $(ZLIB_INCLUDE)
./ADSupport/supportApp/hdf5_hlSrc/Makefile:        USR_INCLUDES += $(SZIP_INCLUDE)
./ADSupport/supportApp/hdf5_hlSrc/Makefile:        USR_INCLUDES += $(ZLIB_INCLUDE)
./ADSupport/supportApp/bloscSrc/Makefile:        USR_INCLUDES += $(ZLIB_INCLUDE)
./ADCore/ADApp/pluginSrc/Makefile:    USR_INCLUDES += $(GRAPHICSMAGICK_INCLUDE)
./ADCore/ADApp/pluginTests/Makefile:#  USR_INCLUDES += $(HDF5_INCLUDE)
From: [email protected] <[email protected]> on behalf of Jörn Dreyer <[email protected]>
Sent: Monday, November 20, 2017 7:09 AM
To: [email protected]
Subject: Possible bug in areaDetector/ADSupport/supportApp/nexusSrc/Makefile?
on an Debian based Linux system I had some trouble to compile the areaDetector
module. In CONFIG_SITE.local one can define path variables for various
external components. In contrast to most Linux distributions I know, Debian
installs HDF5 in a sub path under /usr/include/hdf5 depending on the version
of HDF5 that is installed (serial, openmpi, openmpich...) So one has to set up
the correct path in CONFIG_SITE.local. By doing that at using the internal
version of Nexus, I discovered a problem in the Makefile. In this Makefile the
path's for HDF5, SZIP and ZLIB are added to USR_INCLUDES as
USR_INCLUDES += $(HDF5_INCLUDES)
While in all other Makefiles this is included as
USR_INCLUDES += -I$(HDF5_INCLUDES)
The compilation then fails with hdf5.h not found. After adding the -I I was
able to compile areaDetector on this system.
Jörn
Possible bug in areaDetector/ADSupport/supportApp/nexusSrc/Makefile? Jörn Dreyer
Re: Possible bug in areaDetector/ADSupport/supportApp/nexusSrc/Makefile? Mark Rivers
Prev: Re: Possible bug in areaDetector/ADSupport/supportApp/nexusSrc/Makefile? Mark Rivers
Next: Re: issue with either camonitor or pcaspy in 3.15? Jameson Graef Rollins
Next: synApps_5_8 compilation error Mrinal Kanti Bera
