As an alternative to the using the core dump, you could rebuild your system and
the IOC using the
"linux-x86_64-debug" EPICS_HOST_ARCH. After that you have to test the IOC to see
if the same
caserverio.c line #357 assert() error occurs under the non-optimized
"linux-x86_64-debug" architecture.
If you can re-create the problem using the "linux-x86_64-debug" architecture,
then you can use a
source-code debugger (e.g., gdb or ddd) to diagnose it. You would need to place
an assembly-code
level breakpoint in the assert() code to determine why the assert() failed.
Ron
On 01/19/2018 10:35 AM, Hinko Kocevar wrote:
Thanks again!
I can see that if I run a faulty app that would trigger core dump the
file is saved into /var/spool/abrt folder.
I can not see IOC core dump there.. Might be due to redhat/centos abrt
service default settings that only saves core dump if the package was
installed using yum or similar. My IOC was not. This, I changed now,
but that means I need to reproduce the crash. Will update you on the
progress.
/Hinko
On Fri, Jan 19, 2018 at 4:17 PM, Michael Davidsaver
<[email protected]> wrote:
On 01/19/2018 12:31 AM, Hinko Kocevar wrote:
if core saving was
enabled at the time of the crash..
Run
ulimit -a
and look for a line like:
core file size (blocks, -c) 0
If this is zero, then core dumps are disabled. Run
ulimit -c unlimited
To enable core dumps. You can use a non-zero
value to limit the core file size, but that's
probably not relevant unless your IOC is using
a _lot_ of memory.
- IOC crash Hinko Kocevar
- Re: IOC crash Mark Rivers
- Re: IOC crash Hinko Kocevar
- Re: IOC crash Michael Davidsaver
Re: Seq-2.2.5 compilation on windows Mark Rivers
RE: Seq-2.2.5 compilation on windows Mark Rivers
<2018>
2025
2026
<2018>
2025
2026
