1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Scanning on event number fails with EPICS 3.16
To: Simon Reiter <[email protected]>, <[email protected]>
Date: Tue, 30 Jan 2018 13:13:37 -0600
Hi Simon,
On 01/30/2018 10:20 AM, Simon Reiter wrote:
> Up to now, my event record has an INP field, which links to a calc record.
> This calc record only provides the correct value under some conditions.
> How can I do this without using a state machine?
> record(calc,"$(BOARDNAME):ErrorFlags:calc")
>   field(INPA, "$(BOARDNAME):InitDone:S CPP")
>   field(CALC, "A ? 2 : 0")
> record(event, "$(BOARDNAME):ErrorFlags:trg")
>   field(INP,  "$(BOARDNAME):ErrorFlags:calc CPP")
> This is my current code. The value of event is now 2.000000 in the
> correct case.
For conditional processing of your event record I would recommend using
the SDIS input link and DISV field which all records have, something
like this:
record(event, "$(BOARDNAME):ErrorFlags:trg") {
    field(VAL, "2")
    field(SDIS, "$(BOARDNAME):InitDone:S CPP")
    field(DISV, 0)
This keeps the event name/number associated with the record rather than
having to go looking at the calc record to work out which event(s) it
might trigger, and it only needs the one record.
See
https://wiki-ext.aps.anl.gov/epics/index.php/RRM_3-14_dbCommon#Scan_Fields
for a description of the scan disable mechanism.
You might have to adjust the value of the DISV field depending on what
your $(BOARDNAME):InitDone:S record actually returns.
HTH,
- Andrew
Re: Scanning on event number fails with EPICS 3.16 Simon Reiter
Re: Scanning on event number fails with EPICS 3.16 Benjamin Franksen
Prev: Re: pvPut error message by Sequencer Andrew Johnson
Next: Re: Scanning on event number fails with EPICS 3.16 Simon Reiter
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Scanning on event number fails with EPICS 3.16 Michael Davidsaver
ANJ, 30 Jan 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
