1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Scanning on event number fails with EPICS 3.16
To: Simon Reiter <[email protected]>
Cc: [email protected]
Date: Tue, 30 Jan 2018 10:32:41 -0800
On 01/30/2018 08:20 AM, Simon Reiter wrote:
> Thanks so far.
> postEvent 2
> works fine.
> Up to now, my event record has an INP field, which links to a calc record.
> This calc record only provides the correct value under some conditions.
> How can I do this without using a state machine?
> record(calc,"$(BOARDNAME):ErrorFlags:calc")
>   field(INPA, "$(BOARDNAME):InitDone:S CPP")
>   field(CALC, "A ? 2 : 0")
> record(event, "$(BOARDNAME):ErrorFlags:trg")
>   field(INP,  "$(BOARDNAME):ErrorFlags:calc CPP")
> This is my current code. The value of event is now 2.000000 in the correct case.
Please have a look at the following example DB, which works as expected for me.
If this result doesn't make sense to you, then please post a complete example DB
which I can use to reproduce your problem.
> cat <<EOF > event.db
> record(event, "evt") {
>   field(VAL , "2")
>   field(TPRO, "1")
> record(longout, "blah") {
>   field(SCAN, "Event")
>   field(EVNT, "2")
>   field(TPRO, "1")
> EOF
I run this with
> $ softIoc -d event.db
I then scan the "evt" record and see that the "blah" record is also processed.
> epics> dbpf evt.PROC 1
> _main_: Process evt
> DBF_UCHAR:          1 = 0x1
> cbLow: Process blah
Scanning on event number fails with EPICS 3.16 Simon Reiter
Re: Scanning on event number fails with EPICS 3.16 Benjamin Franksen
Re: Scanning on event number fails with EPICS 3.16 Simon Reiter
Prev: Re: CAJ and JCA links on website point to SourceForge Andrew Johnson
Next: Re: pvPut error message by Sequencer Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Scanning on event number fails with EPICS 3.16 Simon Reiter
Next: Re: Scanning on event number fails with EPICS 3.16 Andrew Johnson
ANJ, 30 Jan 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
