1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: AreaDetector repository inconsistent
To: Mark Rivers <[email protected]>, "'J. Lewis Muir'" <[email protected]>
Cc: Jörn Dreyer <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 7 Feb 2018 11:41:31 -0600
On 02/05/2018 05:32 PM, Mark Rivers wrote:
In my opinion a new version of synApps should simply be a script:  It does a git clone and git checkout of the last tagged version of every module as of that date. If that's what it did it could be updated frequently.  And users would have a git repository that they could trivially update by going into calc, for example, and grab the latest bug fix by checking out master, or a specific release by checking out R3-7.  It does not make sense to me to be using tar files.
I wrote a script to checkout synApps from github *and* make it easy to keep it up to date. I haven't used it in a while so it may not work without modifications. The documentation for it is here:
https://github.com/kmpeters/epics-scripts/blob/master/docs/synApps.md
I frequently deploy released versions of software using tar files because I want to use git to track changes in the deployed modules and I don't want to accidentally push changes to the master branch. I also like having the version numbers in the directory names; it makes it much easier to see which versions of software an IOC is using (look at its RELEASE file).
I started writing a script that would allow a user to choose which releases or tags to download using the github api (getReleases.py). That script is unfinished and can be found in the github-api branch:
https://github.com/kmpeters/epics-scripts/tree/github-api
Kevin
AreaDetector repository inconsistent Jörn Dreyer
Re: AreaDetector repository inconsistent Ralph Lange
Re: AreaDetector repository inconsistent Jörn Dreyer
Re: AreaDetector repository inconsistent J. Lewis Muir
RE: AreaDetector repository inconsistent Mark Rivers
Prev: RE: AreaDetector repository inconsistent Mark Rivers
Next: Re: AreaDetector repository inconsistent Mooney, Tim M.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: AreaDetector repository inconsistent Benjamin Franksen
Next: Re: AreaDetector repository inconsistent Jeong Han Lee
ANJ, 09 Feb 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
