I have determined that whether or not the non-UTF8 characters are detected depends on the version of Linux on which grep is running.
I just searched all of ADSupport on an RHEL 7 system and it did not find anything.
[epics@corvette ADSupport]$ find . -type f -name '*.c*' -exec grep -H -axv '.*' {} \;
I then did the search on exactly the same physical files, but running the command on a Fedora 26 system that has this file system NFS mounted:
[epics@millenia ADSupport]$ find . -type f -name '*.c*' -exec grep -H -axv '.*' {} \;
./supportApp/GraphicsMagickSrc/lcms/src/cmscgats.c: // measurement. Allowed values are ▒black▒, ▒white▒, or {"na".
./supportApp/GraphicsMagickSrc/lcms/src/cmscgats.c: // values are {"yes▒, ▒white▒, ▒none▒ or ▒na▒.
./supportApp/GraphicsMagickSrc/lcms/src/cmsopt.c: // In this particular optimization, cach▒ does not help as it takes more time to deal with
./supportApp/GraphicsMagickSrc/lcms/src/cmsopt.c: // the cach▒ that with the pixel handling
./supportApp/GraphicsMagickSrc/lcms/src/cmstypes.c: //(see clause 4.1 for the definition of ▒aligned▒). Because the Unicode language
./supportApp/GraphicsMagickSrc/lcms/src/cmstypes.c://The device representation corresponds to the header▒s ▒color space of data▒ field.
./supportApp/GraphicsMagickSrc/lcms/src/cmstypes.c://This representation should be consistent with the ▒number of device components▒
./supportApp/GraphicsMagickSrc/lcms/src/cmstypes.c://The PCS representation corresponds to the header▒s PCS field. The PCS representation
./supportApp/GraphicsMagickSrc/lcms/src/cmstypes.c://CIE ▒absolute▒ illuminant white point tristimulus values and CIE ▒absolute▒
./supportApp/GraphicsMagickSrc/lcms/src/cmstypes.c:// The first curve segment always starts at ▒Infinity, and the last curve segment always ends at +Infinity. The
./supportApp/GraphicsMagickSrc/lcms/src/cmstypes.c:// array = [e11, e12, ▒, e1P, e21, e22, ▒, e2P, ▒, eQ1, eQ2, ▒, eQP, e1, e2, ▒, eQ]
./supportApp/GraphicsMagickSrc/lcms/src/cmstypes.c: // Y = (Max ▒ Min) * (X ^ Gamma) + Min
./supportApp/GraphicsMagickSrc/lcms/src/cmstypes.c: // a = (Max ▒ Min) ^ ( 1 / Gamma)
./supportApp/GraphicsMagickSrc/lcms/src/cmsvirt.c://If R▒sRGB,G▒sRGB, B▒sRGB < 0.04045
./supportApp/GraphicsMagickSrc/lcms/src/cmsvirt.c:// R = R▒sRGB / 12.92
./supportApp/GraphicsMagickSrc/lcms/src/cmsvirt.c:// G = G▒sRGB / 12.92
./supportApp/GraphicsMagickSrc/lcms/src/cmsvirt.c:// B = B▒sRGB / 12.92
./supportApp/GraphicsMagickSrc/lcms/src/cmsvirt.c://else if R▒sRGB,G▒sRGB, B▒sRGB >= 0.04045
./supportApp/GraphicsMagickSrc/lcms/src/cmsvirt.c:// R = ((R▒sRGB + 0.055) / 1.055)^2.4
./supportApp/GraphicsMagickSrc/lcms/src/cmsvirt.c:// G = ((G▒sRGB + 0.055) / 1.055)^2.4
./supportApp/GraphicsMagickSrc/lcms/src/cmsvirt.c:// B = ((B▒sRGB + 0.055) / 1.055)^2.4
./supportApp/GraphicsMagickSrc/lcms/src/cmsxform.c:// Null transformation, only applies formatters. No cach▒
./supportApp/GraphicsMagickSrc/lcms/src/cmsxform.c:// Gamut check, No cach▒, 16 bits.
./supportApp/GraphicsMagickSrc/lcms/src/cmsxform.c:// No gamut check, Cach▒, 16 bits,
./supportApp/GraphicsMagickSrc/lcms/src/cmsxform.c: // Float transforms don't use cach▒, always are non-NULL
./supportApp/GraphicsMagickSrc/lcms/src/cmsxform.c: p ->xform = PrecalculatedXFORMGamutCheck; // Gamut check, no cach▒
./supportApp/GraphicsMagickSrc/lcms/src/cmsxform.c: p ->xform = PrecalculatedXFORM; // No cach▒, no gamut check
./supportApp/GraphicsMagickSrc/lcms/src/cmsxform.c: p ->xform = CachedXFORMGamutCheck; // Gamut check, cach▒
./supportApp/GraphicsMagickSrc/lcms/src/cmsxform.c: p ->xform = CachedXFORM; // No gamut check, cach▒
./supportApp/GraphicsMagickSrc/magick/cdl.c: * Original implementation by Cl▒ment Follet. Additional work by Bob
./supportApp/GraphicsMagickSrc/magick/draw.c:% DrawPathCurveToAbsolute() draws a cubic B▒zier curve from the current
./supportApp/GraphicsMagickSrc/magick/draw.c:% DrawPathCurveToRelative() draws a cubic B▒zier curve from the current
./supportApp/GraphicsMagickSrc/magick/draw.c:% DrawPathCurveToQuadraticBezierAbsolute() draws a quadratic B▒zier curve
./supportApp/GraphicsMagickSrc/magick/draw.c:% DrawPathCurveToQuadraticBezierRelative() draws a quadratic B▒zier curve
./supportApp/GraphicsMagickSrc/magick/draw.c:% B▒zier curve (using absolute coordinates) from the current point to
./supportApp/GraphicsMagickSrc/magick/draw.c:% B▒zier curve (using relative coordinates) from the current point to
./supportApp/GraphicsMagickSrc/magick/draw.c:% DrawPathCurveToSmoothAbsolute() draws a cubic B▒zier curve from the
./supportApp/GraphicsMagickSrc/magick/draw.c:% DrawPathCurveToSmoothRelative() draws a cubic B▒zier curve from the
./supportApp/GraphicsMagickSrc/magick/hclut.c:% GraphicsMagick by Cl▒ment Follet with support from C▒dric Lejeune of
./supportApp/GraphicsMagickSrc/wmf/src/extra/gd/gdtestft.c: char *s = "Hello. ▒▒▒▒ɂ▒▒▒ Qyjpqg,"; /* String to draw. */
I will fix these files to remove the offending characters since it seems to cause Perl to fail.
> -----Original Message-----
> From: Gofron, Kazimierz [mailto:[email protected]]
> Sent: Saturday, February 17, 2018 11:59 AM
> To: Mark Rivers <[email protected]>; [email protected]
> Subject: RE: ADSupport compilation problem due to GraphicsMagick Malformed UTF-8
> character(s)
> Could you please check if those characters are actually converted to UTF8 on your RHEL 7.
> Form windows/linux google-chrome, I am seeing these characters in the github.com. I
> copy/past them into the
> https://github.com/areaDetector/ADSupport/blob/master/supportApp/GraphicsMagickSrc/lc
> ms/src/cmstypes.c#L965
> I copy/past these characters into the UTF8 tool:
> https://sites.google.com/site/nathanlexwww/tools/utf8-convert
> I am seeing them as 6byte instead of usual 2Byte on the github.
> From: Mark Rivers [mailto:[email protected]]
> Sent: Saturday, February 17, 2018 12:48 PM
> To: Gofron, Kazimierz; [email protected]
> Subject: Re: ADSupport compilation problem due to GraphicsMagick Malformed UTF-8
> character(s)
> Any idea why my RHEL 7 system behaves differently from your Debian 8 system? Is it an
> OS language setting?
> ________________________________
> From: Gofron, Kazimierz <[email protected]>
> Sent: Saturday, February 17, 2018 11:35 AM
> To: Mark Rivers; [email protected]
> character(s)
> Hi Mark,
> The non UTF8 characters are seen on linux as well.
> 1. Debian 9 in VirtualBox on Windows 7 host.
> kaz@stretch64:~/epics/ADSupport$ uname -a
> Linux stretch64 4.9.0-3-amd64 #1 SMP Debian 4.9.30-2+deb9u5 (2017-09-19) x86_64
> GNU/Linux
> kaz@stretch64:~/epics$ git clone https://github.com/areaDetector/ADSupport ADSupport
> Cloning into 'ADSupport'...
> remote: Counting objects: 7063, done.
> remote: Compressing objects: 100% (3/3), done.
> remote: Total 7063 (delta 0), reused 1 (delta 0), pack-reused 7060
> Receiving objects: 100% (7063/7063), 25.59 MiB | 3.38 MiB/s, done.
> Resolving deltas: 100% (3660/3660), done.
> kaz@stretch64:~/epics$ cd ADSupport/
> kaz@stretch64:~/epics/ADSupport$ git branch -a
> * master
> remotes/origin/HEAD -> origin/master
> remotes/origin/hdf5-1.10.1-pre1
> remotes/origin/hdf5-1.10.1-pre2
> remotes/origin/master
> kaz@stretch64:~/epics/ADSupport$ grep -n -axv '.*'
> 965: //(see clause 4.1 for the definition of �aligned�). Because the Unicode language
> 3063://The device representation corresponds to the header�s �color space of data� field.
> 3064://This representation should be consistent with the �number of device components�
> 3066://The PCS representation corresponds to the header�s PCS field. The PCS
> representation
> 3811://CIE �absolute� illuminant white point tristimulus values and CIE �absolute�
> 3898:// The first curve segment always starts at �Infinity, and the last curve segment always
> 4174:// array = [e11, e12, �, e1P, e21, e22, �, e2P, �, eQ1, eQ2, �, eQP, e1, e2, �, eQ]
> 4673: // Y = (Max � Min) * (X ^ Gamma) + Min
> 4676: // a = (Max � Min) ^ ( 1 / Gamma)
> 2. Server , debian 8
> kgofron@xf18id-srv2:~/test/ADSupport$ uname -a
> Linux xf18id-srv2 3.16.0-4-amd64 #1 SMP Debian 3.16.43-2+deb8u5 (2017-09-19) x86_64
> GNU/Linux
> kgofron@xf18id-srv2:~/test$ git clone https://github.com/areaDetector/ADSupport
> Receiving objects: 100% (7063/7063), 25.59 MiB | 5.94 MiB/s, done.
> Checking connectivity... done.
> kgofron@xf18id-srv2:~/test$ cd ADSupport
> kgofron@xf18id-srv2:~/test/ADSupport$ git branch -a
> * master
> kgofron@xf18id-srv2:~/test/ADSupport$ grep -n -axv '.*'
> representation
> Kaz
> Sent: Saturday, February 17, 2018 11:40 AM
> character(s)
> Hi Kaz,
> I cannot reproduce your grep of the non-UTF-8 characters. Here is a fresh clone and a grep
> on an RHEL 7 system. The grep command is a copy and paste from your e-mail.
> [epics@corvette scratch]$ git clone
> [email protected]:areaDetector/ADSupport<mailto:[email protected]:areaDetector/ADSupport
> Receiving objects: 100% (7063/7063), 25.59 MiB | 29.57 MiB/s, done.
> [epics@corvette scratch]$ cd ADSupport/supportApp/GraphicsMagickSrc/lcms/src/
> [epics@corvette src]$ grep -n -axv '.*' cmstypes.c
> What do you see if you follow these steps on a Linux system?
> Mark
> Sent: Saturday, February 17, 2018 9:31 AM
> To: Mark Rivers <[email protected]<mailto:[email protected]>>; tech-
> character(s)
> Hi Mark,
> After changing to master branch (was in detached HEAD), I confirmed that the cmstypes.c
> has the UTF8 problem.
> Sqr-1 IXS@IXS_MCM /cygdrive/c/epics/synApps/support/areaDetector-3-
> 2/ADSupport/supportApp/GraphicsMagickSrc/lcms/src
> 965: //(see clause 4.1 for the definition of ▒aligned▒). Because the Unicode language
> 3063://The device representation corresponds to the header▒s ▒color space of data▒ field.
> 3064://This representation should be consistent with the ▒number of device components▒
> 3066://The PCS representation corresponds to the header▒s PCS field. The PCS
> representation
> 3811://CIE ▒absolute▒ illuminant white point tristimulus values and CIE ▒absolute▒
> 3898:// The first curve segment always starts at ▒Infinity, and the last curve segment always
> 4174:// array = [e11, e12, ▒, e1P, e21, e22, ▒, e2P, ▒, eQ1, eQ2, ▒, eQP, e1, e2, ▒, eQ]
> 4673: // Y = (Max ▒ Min) * (X ^ Gamma) + Min
> 4676: // a = (Max ▒ Min) ^ ( 1 / Gamma)
> Now your steps:
> -----------------------------------Step 1
> c:\epics\synApps\support\areaDetector-3-2\ADSupport\supportApp\GraphicsMagickSrc
> \lcms\src>git status .
> On branch master
> Your branch is up to date with 'origin/master'.
> nothing to commit, working tree clean
> ---------------------------------- Step 2
> a) {I do not have the O.windows-x64-static-vs2017 directory}
> 2\ADSupport\supportApp\GraphicsMagickSrc\lcms\src>ls -l
> total 1240
> -rw-r--r-- 1 Sqr-1 IXS 197121 1484 Feb 16 15:21 Makefile
> -rw-r--r-- 1 Sqr-1 IXS 197121 945 Feb 16 15:21 Makefile.am
> -rw-r--r-- 1 Sqr-1 IXS 197121 24192 Feb 16 15:21 Makefile.in
> drwxr-xr-x 1 Sqr-1 IXS 197121 0 Feb 17 10:16 O.Common
> drwxr-xr-x 1 Sqr-1 IXS 197121 0 Feb 17 10:16 O.windows-x64-static
> -rw-r--r-- 1 Sqr-1 IXS 197121 16076 Feb 16 15:21 cmsalpha.c
> -rw-r--r-- 1 Sqr-1 IXS 197121 14439 Feb 16 15:21 cmscam02.c
> -rw-r--r-- 1 Sqr-1 IXS 197121 75151 Feb 16 15:21 cmscgats.c
> -rw-r--r-- 1 Sqr-1 IXS 197121 43741 Feb 16 15:21 cmscnvrt.c
> -rw-r--r-- 1 Sqr-1 IXS 197121 21630 Feb 16 15:21 cmserr.c
> -rw-r--r-- 1 Sqr-1 IXS 197121 38551 Feb 16 15:21 cmsgamma.c
> -rw-r--r-- 1 Sqr-1 IXS 197121 20565 Feb 16 15:21 cmsgmt.c
> -rw-r--r-- 1 Sqr-1 IXS 197121 35846 Feb 16 15:21 cmshalf.c
> -rw-r--r-- 1 Sqr-1 IXS 197121 45687 Feb 16 15:21 cmsintrp.c
> -rw-r--r-- 1 Sqr-1 IXS 197121 60115 Feb 16 15:21 cmsio0.c
> -rw-r--r-- 1 Sqr-1 IXS 197121 36128 Feb 16 15:21 cmsio1.c
> -rw-r--r-- 1 Sqr-1 IXS 197121 53169 Feb 16 15:21 cmslut.c
> -rw-r--r-- 1 Sqr-1 IXS 197121 9806 Feb 16 15:21 cmsmd5.c
> -rw-r--r-- 1 Sqr-1 IXS 197121 5858 Feb 16 15:21 cmsmtrx.c
> -rw-r--r-- 1 Sqr-1 IXS 197121 29205 Feb 16 15:21 cmsnamed.c
> -rw-r--r-- 1 Sqr-1 IXS 197121 66034 Feb 16 15:21 cmsopt.c
> -rw-r--r-- 1 Sqr-1 IXS 197121 112503 Feb 16 15:21 cmspack.c
> -rw-r--r-- 1 Sqr-1 IXS 197121 26406 Feb 16 15:21 cmspcs.c
> -rw-r--r-- 1 Sqr-1 IXS 197121 28939 Feb 16 15:21 cmsplugin.c
> -rw-r--r-- 1 Sqr-1 IXS 197121 48476 Feb 16 15:21 cmsps2.c
> -rw-r--r-- 1 Sqr-1 IXS 197121 18399 Feb 16 15:21 cmssamp.c
> -rw-r--r-- 1 Sqr-1 IXS 197121 19820 Feb 16 15:21 cmssm.c
> -rw-r--r-- 1 Sqr-1 IXS 197121 186719 Feb 17 09:34 cmstypes.c
> -rw-r--r-- 1 Sqr-1 IXS 197121 38122 Feb 16 15:21 cmsvirt.c
> -rw-r--r-- 1 Sqr-1 IXS 197121 11330 Feb 16 15:21 cmswtpnt.c
> -rw-r--r-- 1 Sqr-1 IXS 197121 49131 Feb 16 15:21 cmsxform.c
> -rw-r--r-- 1 Sqr-1 IXS 197121 22867 Feb 16 15:21 lcms2.def
> -rw-r--r-- 1 Sqr-1 IXS 197121 37465 Feb 16 15:21 lcms2_internal.h
> b)
> 2\ADSupport\supportApp\GraphicsMagickSrc\lcms\src>del O.windows-x64-static-
> vs2017\cmstypes.obj
> The system cannot find the file specified.
> c)
> 2\ADSupport\supportApp\GraphicsMagickSrc\lcms\src>make
> make -C O.windows-x64-static -f ../Makefile TOP=../../../../.. \
> T_A=windows-x64-static install
> make[1]: Entering directory 'c:/epics/synApps/support/areaDetector-3-
> 2/ADSupport/supportApp/GraphicsMagickSrc/lcms/src/O.windows-x64-static'
> perl -CSD c:/epics/base-7.0.1/bin/windows-x64-static/mkmf.pl -m cmstypes.d -I. -
> I../O.Common -I. -I. -I.. -I../../../../../include/compiler
> /msvc -I../../../../../include/os/WIN32 -I../../../../../include -IC:/epics/synApps/support/asyn-
> R4-33/include -IC:/epics/synApps/s
> upport/areaDetector-3-2/ADSupport/include/os/WIN32 -
> IC:/epics/synApps/support/areaDetector-3-2/ADSupport/include -IC:/epics/synApps/suppor
> t/areaDetector-3-2/ADCore/include -Ic:/epics/base-7.0.1/include/compiler/msvc -
> Ic:/epics/base-7.0.1/include/os/WIN32 -Ic:/epics/base-7.0.1/i
> nclude -I../../../../../supportApp/GraphicsMagickSrc/lcms/include cmstypes.obj
> ../cmstypes.c
> Malformed UTF-8 character (fatal) at c:/epics/base-7.0.1/bin/windows-x64-static/mkmf.pl
> line 137, <FILE> line 5573.
> make[1]: Nothing to be done for 'install'.
> make[1]: Leaving directory 'c:/epics/synApps/support/areaDetector-3-
> a2)
> 2\ADSupport\supportApp\GraphicsMagickSrc\lcms\src\O.windows-x64-static>del
> cmstypes.obj
> 2\ADSupport\supportApp\GraphicsMagickSrc\lcms\src\O.windows-x64-static>cd ..
> ../cmstypes.c
> cl -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -
> D_CRT_NONSTDC_NO_DEPRECATE -Ox -Oy- -W3 -D_LCMSLIB_ -DWIN64 -
> D_VIS
> UALC_ -D_LIB -MT -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/msvc -
> /../include -IC:/epics/synApps/support/asyn-R4-33/include -
> IC:/epics/synApps/support/areaDetector-3-2/ADSupport/include/os/WIN32 -I
> IC:/epics/synApps/support/areaDetector-3-2/ADCore/include -Ic:/epics/base-7.0
> .1/include/compiler/msvc -Ic:/epics/base-7.0.1/include/os/WIN32 -Ic:/epics/base-
> 7.0.1/include -I../../../../../supportApp/GraphicsMagick
> Src/lcms/include -c ../cmstypes.c
> cmstypes.c
> lib -nologo -verbose -out:lcms.lib cmsalpha.obj cmscam02.obj cmscgats.obj
> cmscnvrt.obj cmserr.obj cmsgamma.obj cmsgmt.obj cmshalf.ob
> j cmsintrp.obj cmsio0.obj cmsio1.obj cmslut.obj cmsmd5.obj cmsmtrx.obj cmsnamed.obj
> cmsopt.obj cmspack.obj cmspcs.obj cmsplugin.obj cmsps2.o
> bj cmssamp.obj cmssm.obj cmstypes.obj cmsvirt.obj cmswtpnt.obj cmsxform.obj
> Appending cmsxform.obj
> Appending cmswtpnt.obj
> Appending cmsvirt.obj
> Appending cmstypes.obj
> Appending cmssm.obj
> Appending cmssamp.obj
> Appending cmsps2.obj
> Appending cmsplugin.obj
> Appending cmspcs.obj
> Appending cmspack.obj
> Appending cmsopt.obj
> Appending cmsnamed.obj
> Appending cmsmtrx.obj
> Appending cmsmd5.obj
> Appending cmslut.obj
> Appending cmsio1.obj
> Appending cmsio0.obj
> Appending cmsintrp.obj
> Appending cmshalf.obj
> Appending cmsgmt.obj
> Appending cmsgamma.obj
> Appending cmserr.obj
> Appending cmscnvrt.obj
> Appending cmscgats.obj
> Appending cmscam02.obj
> Appending cmsalpha.obj
> Installing library ../../../../../lib/windows-x64-static/lcms.lib
> My installation is cloned directly to Windows from github, but previously I cloned to
> debian9 virtual machine, and copied through shared folder to Windows with same compile
> errors. The compilation is reproducible on two Windows 7 systems.
> -Kaz
> Sent: Saturday, February 17, 2018 8:26 AM
> To: Gofron, Kazimierz; [email protected]<mailto:[email protected]>
> character(s)
> Hi Kaz,
> I just tested compiling that file on my system. The following shows that I am using the git
> master version of that file, and that I don’t get any error compiling it with VS 2017. Can
> you please execute these exact same 3 commands on your system? Check out the master
> branch first. In the output below I inserted line breaks into the cl output to make it easier to
> read.
> One difference could be that my working directory is on a Linux system, not on a Windows
> system. I have the Linux file system mounted from the Windows machine. Perhaps there is
> some character translation happening either with the git checkout on Linux, or when serving
> the files to Windows?
> J:\epics\devel\areaDetector-3-2\ADSupport\supportApp\GraphicsMagickSrc\lcms\src>git
> status .
> On branch master
> Your branch is up-to-date with 'origin/master'.
> J:\epics\devel\areaDetector-3-2\ADSupport\supportApp\GraphicsMagickSrc\lcms\src>del
> O.windows-x64-static-vs2017\cmstypes.obj
> J:\epics\devel\areaDetector-3-2\ADSupport\supportApp\GraphicsMagickSrc\lcms\src>make
> make -C O.windows-x64-static-vs2017 -f ../Makefile TOP=../../../../.. \
> T_A=windows-x64-static-vs2017 install
> make[1]: Entering directory 'J:/epics/devel/areaDetector-3-
> 2/ADSupport/supportApp/GraphicsMagickSrc/lcms/src/O.windows-x64-static-vs2017'
> -D_LCMSLIB_ -DWIN64 -D_VISUALC_ -D_LIB -MT -I. -I../O.Common
> -I. -I. -I.. -I../../../../../include/compiler/msvc -I../../../../../include/os/WIN32 -I../../../../../include
> -IJ:/epics/devel/asyn-4-33/include/compiler/msvc -IJ:/epics/devel/asyn-4-33/include
> -IJ:/epics/devel/areaDetector-3-2/ADSupport/include/os/WIN32 -
> -IJ:/epics/devel/areaDetector-3-2/ADCore/include -IH:/epics-devel/base-
> -IH:/epics-devel/base-7.0.1/include/os/WIN32 -IH:/epics-devel/base-7.0.1/include
> -I../../../../../supportApp/GraphicsMagickSrc/lcms/include -c ../cmstypes.c
> cmstypes.c
> cmscnvrt.obj cmserr.obj cmsgamma.obj cmsgmt.obj cmshalf.obj cmsintrp.obj cmsio0.obj
> cmsio1.obj cmslut.obj cmsmd5.obj cmsmtrx.obj cmsnamed.obj cmsopt.obj cmspack.obj
> cmspcs.obj cmsplugin.obj cmsps2.obj cmssamp.obj cmssm.obj cmstypes.obj cmsvirt.obj
> Appending cmssm.obj
> "Installing library ../../../../../lib/windows-x64-static-vs2017/lcms.lib"
> make[1]: Leaving directory 'J:/epics/devel/areaDetector-3-
> Sent: Saturday, February 17, 2018 7:03 AM
> character(s)
> Hi Mark,
> The ADSupport compilation error is originating from non compatible UTF-8 characters in
> cmstypes.c file. That compilation error went away after changing characters to UTF-8
> format.
> For now, I placed a UTF-8 compatible file here:
> https://github.com/kgofron/synAppsRelease/blob/master/SCRIPTS/ADSupportRepair/cmsty
> pes.c
> I wonder whether you have another installation of GraphicsMagick on your system.
> The characters not following UTF-8 format are on following lines of cmstypes.c file. I
> checked few and they have 24 bit/6byte, instead of 2Byte(UTF-8). They are in comments
> area, and typically are left-quote/right-quote, ellipses single character (…), elongated minus,
> etc.
> ms/src/cmstypes.c#L3063
> ms/src/cmstypes.c#L3064
> ms/src/cmstypes.c#L3066
> ms/src/cmstypes.c#L3811
> ms/src/cmstypes.c#L3898
> ms/src/cmstypes.c#L4174
> ms/src/cmstypes.c#L4673
> ms/src/cmstypes.c#L4676
> UTF8<=> converter
> Line 965 1st non-compatible character uses left quote (Hex C293220A, RFC4648:wpMK).
> -Kaz
> Sent: Friday, February 16, 2018 11:46 PM
> character(s)
> > There is a compilation error when compiling ADSupport of areaDetector 3.2 with base-7.
> This error is related to GraphicsMagic.
> I cannot reproduce that problem. I have rebuilt ADSupport several times and the strings
> “Malformed” or “UTF-8” do not occur in the output. I used “make –sj8”. I am using the
> master branch of ADSupport.
> I am using the same setup as Kaz:
> base-7.0.1.1
> VisualStudio 2017
> make-4.2.1
> Windows 7 Pro 64 bit
> windows-x64-static
> I do note that by switching to make 4.2.1 I no longer see the hangup when using “make –sj”
> which I did see with make 4.1. make 4.1 would always hang when building
> ADSupport/supportApp/hdf5Src with with make –sj. It did always work with make –sj8.
> Mark
> From: [email protected]<mailto:[email protected]> [mailto:tech-
> [email protected]] On Behalf Of Gofron, Kazimierz
> Sent: Friday, February 16, 2018 9:31 PM
> To: [email protected]<mailto:[email protected]>
> Cc: Gofron, Kazimierz <[email protected]<mailto:[email protected]>>
> Subject: ADSupport compilation problem due to GraphicsMagick Malformed UTF-8
> character(s)
> Hi,
> base-7.0.1.1
> VisualStudio 2017
> make-4.2.1
> windows-x64-static
> When compiling ADSupport, the following error is displayed twice:
> Appending buf.obj
> line 136, <FILE> line 5573.
> jbig.c
> BZIP compiling as library
> Kazimierz Gofron
> NSLS-II Controls Group
> Brookhaven National Laboratory
> (p) +1 (631) 344 5283
> (f) +1 (631) 344 8085
> (e) [email protected]<mailto:[email protected]>
> (w) www.bnl.gov/nsls2<http://www.bnl.gov/nsls2>
- RE: ADSupport compilation problem due to GraphicsMagick Malformed UTF-8 character(s) Mark Rivers
- ADSupport compilation problem due to GraphicsMagick Malformed UTF-8 character(s) Gofron, Kazimierz
- RE: ADSupport compilation problem due to GraphicsMagick Malformed UTF-8 character(s) Gofron, Kazimierz
- Re: ADSupport compilation problem due to GraphicsMagick Malformed UTF-8 character(s) Mark Rivers
<2018>
2025
2026
<2018>
2025
2026
