I can tell from the context that these are 8-bit ASCII Windows
characters like opening and closing quotes.
They may have been generated by copying and pasting from a Word
document - and IMHO they're evil.
Can you contact the issuer to get this fixed? (for once and all?)
If they have only ever used/compiled this on Windows they may not even
know that there is a problem.
Maren
On Sat, Feb 17, 2018 at 10:29 AM, Mark Rivers <[email protected]> wrote:
>> I will fix these files to remove the offending characters since it seems to cause Perl to fail.
> On second thought I would like to get input from Andrew Johnson or others on whether it would be possible to have Perl simply not generate the fatal error in this case. I am reluctant to change those files, because they are from the GraphicsMagick distribution, and then we need to patch them each time we get a new release.
> Mark
>> -----Original Message-----
>> From: [email protected] [mailto:[email protected]] On Behalf
>> Of Mark Rivers
>> Sent: Saturday, February 17, 2018 2:18 PM
>> To: 'Gofron, Kazimierz' <[email protected]>; [email protected]
>> Subject: RE: ADSupport compilation problem due to GraphicsMagick Malformed UTF-8
>> character(s)
>> I have determined that whether or not the non-UTF8 characters are detected depends on the
>> version of Linux on which grep is running.
>> I just searched all of ADSupport on an RHEL 7 system and it did not find anything.
>> [epics@corvette ADSupport]$ find . -type f -name '*.c*' -exec grep -H -axv '.*' {} \;
>> I then did the search on exactly the same physical files, but running the command on a
>> Fedora 26 system that has this file system NFS mounted:
>> [epics@millenia ADSupport]$ find . -type f -name '*.c*' -exec grep -H -axv '.*' {} \;
>> ./supportApp/GraphicsMagickSrc/lcms/src/cmscgats.c: // measurement.
>> Allowed values are ▒black▒, ▒white▒, or {"na".
>> ./supportApp/GraphicsMagickSrc/lcms/src/cmscgats.c: // values are
>> {"yes▒, ▒white▒, ▒none▒ or ▒na▒.
>> ./supportApp/GraphicsMagickSrc/lcms/src/cmsopt.c: // In this particular optimization,
>> cach▒ does not help as it takes more time to deal with
>> ./supportApp/GraphicsMagickSrc/lcms/src/cmsopt.c: // the cach▒ that with the pixel
>> handling
>> ./supportApp/GraphicsMagickSrc/lcms/src/cmstypes.c: //(see clause 4.1 for the definition
>> of ▒aligned▒). Because the Unicode language
>> ./supportApp/GraphicsMagickSrc/lcms/src/cmstypes.c://The device representation
>> corresponds to the header▒s ▒color space of data▒ field.
>> ./supportApp/GraphicsMagickSrc/lcms/src/cmstypes.c://This representation should be
>> consistent with the ▒number of device components▒
>> ./supportApp/GraphicsMagickSrc/lcms/src/cmstypes.c://The PCS representation corresponds
>> to the header▒s PCS field. The PCS representation
>> ./supportApp/GraphicsMagickSrc/lcms/src/cmstypes.c://CIE ▒absolute▒ illuminant white
>> point tristimulus values and CIE ▒absolute▒
>> ./supportApp/GraphicsMagickSrc/lcms/src/cmstypes.c:// The first curve segment always
>> starts at ▒Infinity, and the last curve segment always ends at +Infinity. The
>> ./supportApp/GraphicsMagickSrc/lcms/src/cmstypes.c:// array = [e11, e12, ▒, e1P, e21, e22,
>> ▒, e2P, ▒, eQ1, eQ2, ▒, eQP, e1, e2, ▒, eQ]
>> ./supportApp/GraphicsMagickSrc/lcms/src/cmstypes.c: // Y = (Max ▒ Min) * (X ^
>> Gamma) + Min
>> ./supportApp/GraphicsMagickSrc/lcms/src/cmstypes.c: // a = (Max ▒ Min) ^ ( 1 /
>> Gamma)
>> ./supportApp/GraphicsMagickSrc/lcms/src/cmsvirt.c://If R▒sRGB,G▒sRGB, B▒sRGB <
>> 0.04045
>> ./supportApp/GraphicsMagickSrc/lcms/src/cmsvirt.c:// R = R▒sRGB / 12.92
>> ./supportApp/GraphicsMagickSrc/lcms/src/cmsvirt.c:// G = G▒sRGB / 12.92
>> ./supportApp/GraphicsMagickSrc/lcms/src/cmsvirt.c:// B = B▒sRGB / 12.92
>> ./supportApp/GraphicsMagickSrc/lcms/src/cmsvirt.c://else if R▒sRGB,G▒sRGB, B▒sRGB
>> >= 0.04045
>> ./supportApp/GraphicsMagickSrc/lcms/src/cmsvirt.c:// R = ((R▒sRGB + 0.055) /
>> 1.055)^2.4
>> ./supportApp/GraphicsMagickSrc/lcms/src/cmsvirt.c:// G = ((G▒sRGB + 0.055) /
>> 1.055)^2.4
>> ./supportApp/GraphicsMagickSrc/lcms/src/cmsvirt.c:// B = ((B▒sRGB + 0.055) /
>> 1.055)^2.4
>> ./supportApp/GraphicsMagickSrc/lcms/src/cmsxform.c:// Null transformation, only applies
>> formatters. No cach▒
>> ./supportApp/GraphicsMagickSrc/lcms/src/cmsxform.c:// Gamut check, No cach▒, 16 bits.
>> ./supportApp/GraphicsMagickSrc/lcms/src/cmsxform.c:// No gamut check, Cach▒, 16 bits,
>> ./supportApp/GraphicsMagickSrc/lcms/src/cmsxform.c: // Float transforms don't use
>> cach▒, always are non-NULL
>> ./supportApp/GraphicsMagickSrc/lcms/src/cmsxform.c: p ->xform =
>> PrecalculatedXFORMGamutCheck; // Gamut check, no cach▒
>> PrecalculatedXFORM; // No cach▒, no gamut check
>> CachedXFORMGamutCheck; // Gamut check, cach▒
>> CachedXFORM; // No gamut check, cach▒
>> ./supportApp/GraphicsMagickSrc/magick/cdl.c: * Original implementation by Cl▒ment
>> Follet. Additional work by Bob
>> ./supportApp/GraphicsMagickSrc/magick/draw.c:% DrawPathCurveToAbsolute() draws a
>> cubic B▒zier curve from the current
>> ./supportApp/GraphicsMagickSrc/magick/draw.c:% DrawPathCurveToRelative() draws a
>> DrawPathCurveToQuadraticBezierAbsolute() draws a quadratic B▒zier curve
>> DrawPathCurveToQuadraticBezierRelative() draws a quadratic B▒zier curve
>> ./supportApp/GraphicsMagickSrc/magick/draw.c:% B▒zier curve (using absolute
>> coordinates) from the current point to
>> ./supportApp/GraphicsMagickSrc/magick/draw.c:% B▒zier curve (using relative
>> ./supportApp/GraphicsMagickSrc/magick/draw.c:% DrawPathCurveToSmoothAbsolute()
>> draws a cubic B▒zier curve from the
>> ./supportApp/GraphicsMagickSrc/magick/draw.c:% DrawPathCurveToSmoothRelative()
>> ./supportApp/GraphicsMagickSrc/magick/hclut.c:% GraphicsMagick by Cl▒ment Follet
>> with support from C▒dric Lejeune of
>> ./supportApp/GraphicsMagickSrc/wmf/src/extra/gd/gdtestft.c: char *s = "Hello.
>> ▒▒▒▒ɂ▒▒▒ Qyjpqg,"; /* String to draw. */
>> Mark
>> > From: Gofron, Kazimierz [mailto:[email protected]]
>> > Sent: Saturday, February 17, 2018 11:59 AM
>> > To: Mark Rivers <[email protected]>; [email protected]
>> > character(s)
>> > Could you please check if those characters are actually converted to UTF8 on your RHEL
>> 7.
>> > Form windows/linux google-chrome, I am seeing these characters in the github.com. I
>> > copy/past them into the
>> https://github.com/areaDetector/ADSupport/blob/master/supportApp/GraphicsMagickSrc/lc
>> > ms/src/cmstypes.c#L965
>> > I copy/past these characters into the UTF8 tool:
>> > https://sites.google.com/site/nathanlexwww/tools/utf8-convert
>> > I am seeing them as 6byte instead of usual 2Byte on the github.
>> > From: Mark Rivers [mailto:[email protected]]
>> > Sent: Saturday, February 17, 2018 12:48 PM
>> > To: Gofron, Kazimierz; [email protected]
>> > Subject: Re: ADSupport compilation problem due to GraphicsMagick Malformed UTF-8
>> > character(s)
>> > Any idea why my RHEL 7 system behaves differently from your Debian 8 system? Is it
>> an
>> > OS language setting?
>> > ________________________________
>> > From: Gofron, Kazimierz <[email protected]>
>> > Sent: Saturday, February 17, 2018 11:35 AM
>> > To: Mark Rivers; [email protected]
>> > character(s)
>> > Hi Mark,
>> > The non UTF8 characters are seen on linux as well.
>> > 1. Debian 9 in VirtualBox on Windows 7 host.
>> > kaz@stretch64:~/epics/ADSupport$ uname -a
>> > Linux stretch64 4.9.0-3-amd64 #1 SMP Debian 4.9.30-2+deb9u5 (2017-09-19) x86_64
>> > GNU/Linux
>> > kaz@stretch64:~/epics$ git clone https://github.com/areaDetector/ADSupport ADSupport
>> > Cloning into 'ADSupport'...
>> > remote: Counting objects: 7063, done.
>> > remote: Compressing objects: 100% (3/3), done.
>> > remote: Total 7063 (delta 0), reused 1 (delta 0), pack-reused 7060
>> > Receiving objects: 100% (7063/7063), 25.59 MiB | 3.38 MiB/s, done.
>> > Resolving deltas: 100% (3660/3660), done.
>> > kaz@stretch64:~/epics$ cd ADSupport/
>> > kaz@stretch64:~/epics/ADSupport$ git branch -a
>> > * master
>> > remotes/origin/HEAD -> origin/master
>> > remotes/origin/hdf5-1.10.1-pre1
>> > remotes/origin/hdf5-1.10.1-pre2
>> > remotes/origin/master
>> > kaz@stretch64:~/epics/ADSupport$ grep -n -axv '.*'
>> > 965: //(see clause 4.1 for the definition of �aligned�). Because the Unicode language
>> > 3063://The device representation corresponds to the header�s �color space of data�
>> field.
>> > 3064://This representation should be consistent with the �number of device components�
>> > 3066://The PCS representation corresponds to the header�s PCS field. The PCS
>> > representation
>> > 3811://CIE �absolute� illuminant white point tristimulus values and CIE �absolute�
>> > 3898:// The first curve segment always starts at �Infinity, and the last curve segment
>> always
>> > 4174:// array = [e11, e12, �, e1P, e21, e22, �, e2P, �, eQ1, eQ2, �, eQP, e1, e2, �, eQ]
>> > 4673: // Y = (Max � Min) * (X ^ Gamma) + Min
>> > 4676: // a = (Max � Min) ^ ( 1 / Gamma)
>> > 2. Server , debian 8
>> > kgofron@xf18id-srv2:~/test/ADSupport$ uname -a
>> > Linux xf18id-srv2 3.16.0-4-amd64 #1 SMP Debian 3.16.43-2+deb8u5 (2017-09-19)
>> x86_64
>> > GNU/Linux
>> > kgofron@xf18id-srv2:~/test$ git clone https://github.com/areaDetector/ADSupport
>> > Receiving objects: 100% (7063/7063), 25.59 MiB | 5.94 MiB/s, done.
>> > Checking connectivity... done.
>> > kgofron@xf18id-srv2:~/test$ cd ADSupport
>> > kgofron@xf18id-srv2:~/test/ADSupport$ git branch -a
>> > * master
>> > kgofron@xf18id-srv2:~/test/ADSupport$ grep -n -axv '.*'
>> field.
>> > representation
>> always
>> > Kaz
>> > Sent: Saturday, February 17, 2018 11:40 AM
>> > character(s)
>> > Hi Kaz,
>> > I cannot reproduce your grep of the non-UTF-8 characters. Here is a fresh clone and a
>> grep
>> > on an RHEL 7 system. The grep command is a copy and paste from your e-mail.
>> > [epics@corvette scratch]$ git clone
>> [email protected]:areaDetector/ADSupport<mailto:[email protected]:areaDetector/ADSupport
>> > Receiving objects: 100% (7063/7063), 25.59 MiB | 29.57 MiB/s, done.
>> > [epics@corvette scratch]$ cd ADSupport/supportApp/GraphicsMagickSrc/lcms/src/
>> > [epics@corvette src]$ grep -n -axv '.*' cmstypes.c
>> > What do you see if you follow these steps on a Linux system?
>> > Mark
>> > Sent: Saturday, February 17, 2018 9:31 AM
>> > To: Mark Rivers <[email protected]<mailto:[email protected]>>; tech-
>> > character(s)
>> > Hi Mark,
>> > After changing to master branch (was in detached HEAD), I confirmed that the
>> cmstypes.c
>> > has the UTF8 problem.
>> > Sqr-1 IXS@IXS_MCM /cygdrive/c/epics/synApps/support/areaDetector-3-
>> > 2/ADSupport/supportApp/GraphicsMagickSrc/lcms/src
>> > 965: //(see clause 4.1 for the definition of ▒aligned▒). Because the Unicode language
>> > 3063://The device representation corresponds to the header▒s ▒color space of data▒
>> field.
>> > 3064://This representation should be consistent with the ▒number of device components▒
>> > 3066://The PCS representation corresponds to the header▒s PCS field. The PCS
>> > representation
>> > 3811://CIE ▒absolute▒ illuminant white point tristimulus values and CIE ▒absolute▒
>> > 3898:// The first curve segment always starts at ▒Infinity, and the last curve segment
>> always
>> > 4174:// array = [e11, e12, ▒, e1P, e21, e22, ▒, e2P, ▒, eQ1, eQ2, ▒, eQP, e1, e2, ▒, eQ]
>> > 4673: // Y = (Max ▒ Min) * (X ^ Gamma) + Min
>> > 4676: // a = (Max ▒ Min) ^ ( 1 / Gamma)
>> > Now your steps:
>> > -----------------------------------Step 1
>> > c:\epics\synApps\support\areaDetector-3-2\ADSupport\supportApp\GraphicsMagickSrc
>> > \lcms\src>git status .
>> > On branch master
>> > Your branch is up to date with 'origin/master'.
>> > nothing to commit, working tree clean
>> > ---------------------------------- Step 2
>> > a) {I do not have the O.windows-x64-static-vs2017 directory}
>> > 2\ADSupport\supportApp\GraphicsMagickSrc\lcms\src>ls -l
>> > total 1240
>> > -rw-r--r-- 1 Sqr-1 IXS 197121 1484 Feb 16 15:21 Makefile
>> > -rw-r--r-- 1 Sqr-1 IXS 197121 945 Feb 16 15:21 Makefile.am
>> > -rw-r--r-- 1 Sqr-1 IXS 197121 24192 Feb 16 15:21 Makefile.in
>> > drwxr-xr-x 1 Sqr-1 IXS 197121 0 Feb 17 10:16 O.Common
>> > drwxr-xr-x 1 Sqr-1 IXS 197121 0 Feb 17 10:16 O.windows-x64-static
>> > -rw-r--r-- 1 Sqr-1 IXS 197121 16076 Feb 16 15:21 cmsalpha.c
>> > -rw-r--r-- 1 Sqr-1 IXS 197121 14439 Feb 16 15:21 cmscam02.c
>> > -rw-r--r-- 1 Sqr-1 IXS 197121 75151 Feb 16 15:21 cmscgats.c
>> > -rw-r--r-- 1 Sqr-1 IXS 197121 43741 Feb 16 15:21 cmscnvrt.c
>> > -rw-r--r-- 1 Sqr-1 IXS 197121 21630 Feb 16 15:21 cmserr.c
>> > -rw-r--r-- 1 Sqr-1 IXS 197121 38551 Feb 16 15:21 cmsgamma.c
>> > -rw-r--r-- 1 Sqr-1 IXS 197121 20565 Feb 16 15:21 cmsgmt.c
>> > -rw-r--r-- 1 Sqr-1 IXS 197121 35846 Feb 16 15:21 cmshalf.c
>> > -rw-r--r-- 1 Sqr-1 IXS 197121 45687 Feb 16 15:21 cmsintrp.c
>> > -rw-r--r-- 1 Sqr-1 IXS 197121 60115 Feb 16 15:21 cmsio0.c
>> > -rw-r--r-- 1 Sqr-1 IXS 197121 36128 Feb 16 15:21 cmsio1.c
>> > -rw-r--r-- 1 Sqr-1 IXS 197121 53169 Feb 16 15:21 cmslut.c
>> > -rw-r--r-- 1 Sqr-1 IXS 197121 9806 Feb 16 15:21 cmsmd5.c
>> > -rw-r--r-- 1 Sqr-1 IXS 197121 5858 Feb 16 15:21 cmsmtrx.c
>> > -rw-r--r-- 1 Sqr-1 IXS 197121 29205 Feb 16 15:21 cmsnamed.c
>> > -rw-r--r-- 1 Sqr-1 IXS 197121 66034 Feb 16 15:21 cmsopt.c
>> > -rw-r--r-- 1 Sqr-1 IXS 197121 112503 Feb 16 15:21 cmspack.c
>> > -rw-r--r-- 1 Sqr-1 IXS 197121 26406 Feb 16 15:21 cmspcs.c
>> > -rw-r--r-- 1 Sqr-1 IXS 197121 28939 Feb 16 15:21 cmsplugin.c
>> > -rw-r--r-- 1 Sqr-1 IXS 197121 48476 Feb 16 15:21 cmsps2.c
>> > -rw-r--r-- 1 Sqr-1 IXS 197121 18399 Feb 16 15:21 cmssamp.c
>> > -rw-r--r-- 1 Sqr-1 IXS 197121 19820 Feb 16 15:21 cmssm.c
>> > -rw-r--r-- 1 Sqr-1 IXS 197121 186719 Feb 17 09:34 cmstypes.c
>> > -rw-r--r-- 1 Sqr-1 IXS 197121 38122 Feb 16 15:21 cmsvirt.c
>> > -rw-r--r-- 1 Sqr-1 IXS 197121 11330 Feb 16 15:21 cmswtpnt.c
>> > -rw-r--r-- 1 Sqr-1 IXS 197121 49131 Feb 16 15:21 cmsxform.c
>> > -rw-r--r-- 1 Sqr-1 IXS 197121 22867 Feb 16 15:21 lcms2.def
>> > -rw-r--r-- 1 Sqr-1 IXS 197121 37465 Feb 16 15:21 lcms2_internal.h
>> > b)
>> > 2\ADSupport\supportApp\GraphicsMagickSrc\lcms\src>del O.windows-x64-static-
>> > vs2017\cmstypes.obj
>> > The system cannot find the file specified.
>> > c)
>> > 2\ADSupport\supportApp\GraphicsMagickSrc\lcms\src>make
>> > make -C O.windows-x64-static -f ../Makefile TOP=../../../../.. \
>> > T_A=windows-x64-static install
>> > make[1]: Entering directory 'c:/epics/synApps/support/areaDetector-3-
>> > 2/ADSupport/supportApp/GraphicsMagickSrc/lcms/src/O.windows-x64-static'
>> > perl -CSD c:/epics/base-7.0.1/bin/windows-x64-static/mkmf.pl -m cmstypes.d -I. -
>> > I../O.Common -I. -I. -I.. -I../../../../../include/compiler
>> > /msvc -I../../../../../include/os/WIN32 -I../../../../../include -
>> IC:/epics/synApps/support/asyn-
>> > R4-33/include -IC:/epics/synApps/s
>> > upport/areaDetector-3-2/ADSupport/include/os/WIN32 -
>> > IC:/epics/synApps/support/areaDetector-3-2/ADSupport/include -
>> > t/areaDetector-3-2/ADCore/include -Ic:/epics/base-7.0.1/include/compiler/msvc -
>> > Ic:/epics/base-7.0.1/include/os/WIN32 -Ic:/epics/base-7.0.1/i
>> > nclude -I../../../../../supportApp/GraphicsMagickSrc/lcms/include cmstypes.obj
>> > ../cmstypes.c
>> > Malformed UTF-8 character (fatal) at c:/epics/base-7.0.1/bin/windows-x64-static/mkmf.pl
>> > line 137, <FILE> line 5573.
>> > make[1]: Nothing to be done for 'install'.
>> > make[1]: Leaving directory 'c:/epics/synApps/support/areaDetector-3-
>> > a2)
>> > 2\ADSupport\supportApp\GraphicsMagickSrc\lcms\src\O.windows-x64-static>del
>> > cmstypes.obj
>> > 2\ADSupport\supportApp\GraphicsMagickSrc\lcms\src\O.windows-x64-static>cd ..
>> > ../cmstypes.c
>> > cl -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -
>> > D_CRT_NONSTDC_NO_DEPRECATE -Ox -Oy- -W3 -D_LCMSLIB_ -DWIN64
>> > D_VIS
>> > UALC_ -D_LIB -MT -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/msvc -
>> > /../include -IC:/epics/synApps/support/asyn-R4-33/include -
>> > IC:/epics/synApps/support/areaDetector-3-2/ADSupport/include/os/WIN32 -I
>> > IC:/epics/synApps/support/areaDetector-3-2/ADCore/include -Ic:/epics/base-7.0
>> > .1/include/compiler/msvc -Ic:/epics/base-7.0.1/include/os/WIN32 -Ic:/epics/base-
>> > 7.0.1/include -I../../../../../supportApp/GraphicsMagick
>> > Src/lcms/include -c ../cmstypes.c
>> > cmstypes.c
>> > lib -nologo -verbose -out:lcms.lib cmsalpha.obj cmscam02.obj cmscgats.obj
>> > cmscnvrt.obj cmserr.obj cmsgamma.obj cmsgmt.obj cmshalf.ob
>> > j cmsintrp.obj cmsio0.obj cmsio1.obj cmslut.obj cmsmd5.obj cmsmtrx.obj cmsnamed.obj
>> > cmsopt.obj cmspack.obj cmspcs.obj cmsplugin.obj cmsps2.o
>> > bj cmssamp.obj cmssm.obj cmstypes.obj cmsvirt.obj cmswtpnt.obj cmsxform.obj
>> > Appending cmsxform.obj
>> > Appending cmswtpnt.obj
>> > Appending cmsvirt.obj
>> > Appending cmstypes.obj
>> > Appending cmssm.obj
>> > Appending cmssamp.obj
>> > Appending cmsps2.obj
>> > Appending cmsplugin.obj
>> > Appending cmspcs.obj
>> > Appending cmspack.obj
>> > Appending cmsopt.obj
>> > Appending cmsnamed.obj
>> > Appending cmsmtrx.obj
>> > Appending cmsmd5.obj
>> > Appending cmslut.obj
>> > Appending cmsio1.obj
>> > Appending cmsio0.obj
>> > Appending cmsintrp.obj
>> > Appending cmshalf.obj
>> > Appending cmsgmt.obj
>> > Appending cmsgamma.obj
>> > Appending cmserr.obj
>> > Appending cmscnvrt.obj
>> > Appending cmscgats.obj
>> > Appending cmscam02.obj
>> > Appending cmsalpha.obj
>> > Installing library ../../../../../lib/windows-x64-static/lcms.lib
>> > My installation is cloned directly to Windows from github, but previously I cloned to
>> > debian9 virtual machine, and copied through shared folder to Windows with same
>> compile
>> > errors. The compilation is reproducible on two Windows 7 systems.
>> > -Kaz
>> > Sent: Saturday, February 17, 2018 8:26 AM
>> > To: Gofron, Kazimierz; [email protected]<mailto:[email protected]>
>> > character(s)
>> > Hi Kaz,
>> > I just tested compiling that file on my system. The following shows that I am using the
>> git
>> > master version of that file, and that I don’t get any error compiling it with VS 2017. Can
>> > you please execute these exact same 3 commands on your system? Check out the master
>> > branch first. In the output below I inserted line breaks into the cl output to make it easier
>> to
>> > read.
>> > One difference could be that my working directory is on a Linux system, not on a
>> Windows
>> > system. I have the Linux file system mounted from the Windows machine. Perhaps there
>> is
>> > some character translation happening either with the git checkout on Linux, or when
>> serving
>> > the files to Windows?
>> > J:\epics\devel\areaDetector-3-2\ADSupport\supportApp\GraphicsMagickSrc\lcms\src>git
>> > status .
>> > On branch master
>> > Your branch is up-to-date with 'origin/master'.
>> > J:\epics\devel\areaDetector-3-2\ADSupport\supportApp\GraphicsMagickSrc\lcms\src>del
>> > O.windows-x64-static-vs2017\cmstypes.obj
>> > make -C O.windows-x64-static-vs2017 -f ../Makefile TOP=../../../../.. \
>> > T_A=windows-x64-static-vs2017 install
>> > make[1]: Entering directory 'J:/epics/devel/areaDetector-3-
>> > 2/ADSupport/supportApp/GraphicsMagickSrc/lcms/src/O.windows-x64-static-vs2017'
>> > -D_LCMSLIB_ -DWIN64 -D_VISUALC_ -D_LIB -MT -I. -I../O.Common
>> > -I. -I. -I.. -I../../../../../include/compiler/msvc -I../../../../../include/os/WIN32 -
>> > -IJ:/epics/devel/asyn-4-33/include/compiler/msvc -IJ:/epics/devel/asyn-4-33/include
>> > -IJ:/epics/devel/areaDetector-3-2/ADSupport/include/os/WIN32 -
>> > -IJ:/epics/devel/areaDetector-3-2/ADCore/include -IH:/epics-devel/base-
>> > -IH:/epics-devel/base-7.0.1/include/os/WIN32 -IH:/epics-devel/base-7.0.1/include
>> > -I../../../../../supportApp/GraphicsMagickSrc/lcms/include -c ../cmstypes.c
>> > cmstypes.c
>> > cmscnvrt.obj cmserr.obj cmsgamma.obj cmsgmt.obj cmshalf.obj cmsintrp.obj cmsio0.obj
>> > cmsio1.obj cmslut.obj cmsmd5.obj cmsmtrx.obj cmsnamed.obj cmsopt.obj cmspack.obj
>> > cmspcs.obj cmsplugin.obj cmsps2.obj cmssamp.obj cmssm.obj cmstypes.obj cmsvirt.obj
>> > Appending cmssm.obj
>> > "Installing library ../../../../../lib/windows-x64-static-vs2017/lcms.lib"
>> > make[1]: Leaving directory 'J:/epics/devel/areaDetector-3-
>> > Sent: Saturday, February 17, 2018 7:03 AM
>> > character(s)
>> > Hi Mark,
>> > The ADSupport compilation error is originating from non compatible UTF-8 characters in
>> > cmstypes.c file. That compilation error went away after changing characters to UTF-8
>> > format.
>> > For now, I placed a UTF-8 compatible file here:
>> https://github.com/kgofron/synAppsRelease/blob/master/SCRIPTS/ADSupportRepair/cmsty
>> > pes.c
>> > I wonder whether you have another installation of GraphicsMagick on your system.
>> > The characters not following UTF-8 format are on following lines of cmstypes.c file. I
>> > checked few and they have 24 bit/6byte, instead of 2Byte(UTF-8). They are in comments
>> > area, and typically are left-quote/right-quote, ellipses single character (…), elongated
>> minus,
>> > etc.
>> > ms/src/cmstypes.c#L3063
>> > ms/src/cmstypes.c#L3064
>> > ms/src/cmstypes.c#L3066
>> > ms/src/cmstypes.c#L3811
>> > ms/src/cmstypes.c#L3898
>> > ms/src/cmstypes.c#L4174
>> > ms/src/cmstypes.c#L4673
>> > ms/src/cmstypes.c#L4676
>> > UTF8<=> converter
>> > Line 965 1st non-compatible character uses left quote (Hex C293220A,
>> RFC4648:wpMK).
>> > -Kaz
>> > Sent: Friday, February 16, 2018 11:46 PM
>> > character(s)
>> > > There is a compilation error when compiling ADSupport of areaDetector 3.2 with base-
>> 7.
>> > This error is related to GraphicsMagic.
>> > I cannot reproduce that problem. I have rebuilt ADSupport several times and the strings
>> > “Malformed” or “UTF-8” do not occur in the output. I used “make –sj8”. I am using the
>> > master branch of ADSupport.
>> > I am using the same setup as Kaz:
>> > base-7.0.1.1
>> > VisualStudio 2017
>> > make-4.2.1
>> > Windows 7 Pro 64 bit
>> > windows-x64-static
>> > I do note that by switching to make 4.2.1 I no longer see the hangup when using “make –
>> sj”
>> > which I did see with make 4.1. make 4.1 would always hang when building
>> > ADSupport/supportApp/hdf5Src with with make –sj. It did always work with make –sj8.
>> > Mark
>> > From: [email protected]<mailto:[email protected]>
>> [mailto:tech-
>> > [email protected]] On Behalf Of Gofron, Kazimierz
>> > Sent: Friday, February 16, 2018 9:31 PM
>> > To: [email protected]<mailto:[email protected]>
>> > Cc: Gofron, Kazimierz <[email protected]<mailto:[email protected]>>
>> > Subject: ADSupport compilation problem due to GraphicsMagick Malformed UTF-8
>> > character(s)
>> > Hi,
>> > There is a compilation error when compiling ADSupport of areaDetector 3.2 with base-7.
>> > base-7.0.1.1
>> > VisualStudio 2017
>> > make-4.2.1
>> > windows-x64-static
>> > When compiling ADSupport, the following error is displayed twice:
>> > Appending buf.obj
>> > line 136, <FILE> line 5573.
>> > jbig.c
>> > BZIP compiling as library
>> > Kazimierz Gofron
>> > NSLS-II Controls Group
>> > Brookhaven National Laboratory
>> > (p) +1 (631) 344 5283
>> > (f) +1 (631) 344 8085
>> > (e) [email protected]<mailto:[email protected]>
>> > (w) www.bnl.gov/nsls2<http://www.bnl.gov/nsls2>
- RE: ADSupport compilation problem due to GraphicsMagick Malformed UTF-8 character(s) Gofron, Kazimierz
- ADSupport compilation problem due to GraphicsMagick Malformed UTF-8 character(s) Gofron, Kazimierz
- RE: ADSupport compilation problem due to GraphicsMagick Malformed UTF-8 character(s) Mark Rivers
- Re: ADSupport compilation problem due to GraphicsMagick Malformed UTF-8 character(s) Mark Rivers
Re: ADSupport compilation problem due to GraphicsMagick Malformed UTF-8 character(s) Johnson, Andrew N.
<2018>
2025
2026
<2018>
2025
2026
