1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EtherCAT newbie question
Date: Mon, 19 Feb 2018 21:46:37 +0000
Hi Mark,
We have actually been working on a module to work with the EK9000 Ethernet <-> EtherCAT terminal coupler, which would use Modbus for I/O rather than talking EtherCAT directly.  The nice thing about this is we won’t need a dedicated NIC nor machine to be the EtherCAT master.  In this case the EK9000 will be the master.
Our initial setup:
EK9000 (Ethernet coupler & EtherCAT master)
EL5042 (BiSS-C/SSI absolute encoder module)
EL7041 (Stepper motor module)
We’re basing it off of an equivalent module for the BK9000 (similar but for K-bus terminals) which I believe was also developed in-house at SLAC.  Initially I am developing it for a motion application but the idea is to make it a general purpose module.
In case you are interested we can perhaps upload the code to Github.
Cheers,
Scott
> On 7 Feb 2018, at 1:35 am, [email protected] wrote:
> Hi Mark,
> As Torsten and Jeong Han have already said, the Diamond Ethercat EPICS support is available [1], but it does not support motion.
> For some digital I/O and analog I/O we would use kit from our supported set [2].
> The master in our setup runs on a Dell R310, using Redhat MRG (real time pre-empt rt kernel).
> The minimal ethercat kit would be:  EK1100 coupler, EL1014 (digital input), EL3104 (analogue input), EL2024 (digital output), EL4134 (analogue output).
> Best regards,
> Ronaldo
> [1] https://github.com/dls-controls/ethercat
> [2] See https://epics.anl.gov/tech-talk/2015/msg01665.php
> -----Original Message-----
> From: [email protected] [mailto:[email protected]] On Behalf Of Torsten Bögershausen
> Sent: 07 February 2018 05:29
> To: Mark Rivers; [email protected]
> Hej Mark,
> this is what we use for our motion control test/development crates:
> # CPU: CX5130
> # Configure EL1018 digital input terminal
> # Configure EL2808 digital output terminal
> # Configure EL5101 incremental encoder terminal, motor 1
> # Configure EL5101 incremental encoder terminal, motor 2
> # Configure EL9505 Power supply terminal 5V
> # Configure EL1252 digital input terminal
> # Configure EL7037 stepper drive terminal, motor 1
> # Configure EL7037 stepper drive terminal, motor 2
> (No analog IO in our motion crates ;-)
> No sure if you have access to this page about other terminals for motion:
> https://confluence.esss.lu.se/display/MCAG/Motion+Controller
> HTH
> /Torsten
> PS:
> As Han Lee pointed out, there are different SW packages:
> - Beckhoff TwinCAT
> - Linux ("scanner" from DLS and ecat2 from PSI) (but no motion control)
> - Linux ECMC from ESS http://icalepcs2017.vrws.de/talks/mocpl05_talk.pdf
> And we are happy to help.
> On 06/02/18 20:37, Mark Rivers wrote:
>> I am interested in trying out EtherCAT with a simple inexpensive setup.  What
>> are the minimum parts I need to buy if I want to use the EPICS EtherCAT driver
>> to control some digital I/O, analog I/O, and a stepper motor?  I looked at the
>> Beckhoff website, but I find it overwhelming.
>> Thanks,
>> Mark
> This e-mail and any attachments may contain confidential, copyright and or privileged material, and are for the use of the intended addressee only. If you are not the intended addressee or an authorised recipient of the addressee please notify us of receipt by returning the e-mail and do not use, copy, retain, distribute or disclose the information in or attached to the e-mail.
> Any opinions expressed within this e-mail are those of the individual and not necessarily of Diamond Light Source Ltd.
> Diamond Light Source Ltd. cannot guarantee that this e-mail or any attachments are free from viruses and we cannot accept liability for any damage which you may sustain as a result of software viruses which may be transmitted in or with the message.
> Diamond Light Source Limited (company no. 4375679). Registered in England and Wales with its registered office at Diamond House, Harwell Science and Innovation Campus, Didcot, Oxfordshire, OX11 0DE, United Kingdom
Re: EtherCAT newbie question Jeong Han Lee
EtherCAT newbie question Mark Rivers
Re: EtherCAT newbie question Torsten Bögershausen
RE: EtherCAT newbie question ronaldo.mercado
Prev: RE: ADSupport compilation problem due to GraphicsMagick Malformed UTF-8 character(s) Mark Rivers
Next: Re: EtherCAT newbie question Jeong Han Lee
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: EtherCAT newbie question ronaldo.mercado
ANJ, 19 Feb 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
