On 23/02/18 15:17, Daykin, Evan wrote:
Hi Mark,
Thanks for the reply. We are using asyn 4.33-2 and Stream 2.6-3. The protocol
file has a ReplyTimeout of 2000ms.
Sorry if this is the wrong question, but what is asyn 4.33-2 ?
"git tag" mentions R4-33, not "-2".
And to answer the other question:
>Here's something interesting: asyn behaves correctly for us *only* when the
>client application is killed with SIGKILL, rather than SIGTERM. This results
>in TCP retransmissions and/or refused connections, then normal operation
after >a short while. Is it possible asyn is [un]intentionally not retrying
the >connection if it is closed gracefully?
The code that I see producing "Read from broken connection" is this:
/* If recv() returns 0 on a SOCK_STREAM (TCP) socket, the connection has
closed */
if ((thisRead == 0) && (tty->socketType == SOCK_STREAM)) {
epicsSnprintf(pasynUser->errorMessage,pasynUser->errorMessageSize,
"%s connection closed",
tty->IPDeviceName);
closeConnection(pasynUser,tty,"Read from broken connection");
And then
closeConnection(asynUser *pasynUser,ttyController_t *tty,const char *why)
asynPrint(pasynUser, ASYN_TRACE_FLOW,
"Close %s connection (fd %d): %s\n", tty->IPDeviceName, tty->fd,
why);
So from asyn everything seems to be OK.
It seems that the problem described here:
>2018/02/23 09:51:47.089 test-rf-dcu-n0001.cts:5001 read.
>The last line then repeats rapidly forever.
is caused by the caller into asyn, which is streamdevice ?
There seem to be some improvements in streamdevice,
but I am not familiar with the code.
Dirk, does there ring a bell ?
- Asyn not automatically reconnecting Daykin, Evan
- RE: Asyn not automatically reconnecting Daykin, Evan
Re: Idea for new Display Manager Wang Xiaoqiang (PSI)
<2018>
2025
2026
<2018>
2025
2026
