1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Motor Record not moving distances less than .5
To: "Sobhani, Bayan" <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 15 Mar 2018 16:48:38 +0000
Does you motor actually have an encoder?  If not don't worry about ERES or UEIP, and just set MRES to 1/(steps per engineering unit).
> -----Original Message-----
> From: [email protected] [mailto:[email protected]] On Behalf
> Of Kevin Peterson
> Sent: Thursday, March 15, 2018 11:43 AM
> To: Sobhani, Bayan <[email protected]>; [email protected]
> Subject: Re: Motor Record not moving distances less than .5
> My replies are below.
> On 03/15/2018 09:59 AM, Sobhani, Bayan wrote:
> > UEIP, MRES, and ERES were:
> > UEIP: "No"
> > MRES: 1
> > ERES: 1
> With this configuration you will be unable to make any move smaller than
> 1, since that is the value of MRES.
> > If I try setting UEIP to "Yes", it does not get set and the value remains "No". If I try
> setting ERES to .1, and then setting UEIP to "Yes", I get the following error message:
> > Illegal choice PV: alexHost:testMotor2.UEIP error detected in routine:
> dbFastLinkConv(cvt_st_menu)
> Some motor controllers don't support encoders, which might result in the
> UEIP value being forced to "No," but that doesn't look like what is
> happening here.
> Which client is being used to change the UEIP value?
> What happens if you do a caput from the command line?
>    $ caput alexHost:testMotor2.UEIP "Yes"
> > Alex
> Kevin
Re: Motor Record not moving distances less than .5 Kevin Peterson
Motor Record not moving distances less than .5 Sobhani, Bayan
RE: Motor Record not moving distances less than .5 Sobhani, Bayan
Prev: Re: Motor Record not moving distances less than .5 Kevin Peterson
Next: Re: Motor Record not moving distances less than .5 Kevin Peterson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
ANJ, 15 Mar 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
