1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: CSS xy graph question
To: Jörn Dreyer <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 18 Apr 2018 13:57:19 +0000
Hi Jorn,
Kay just fixed the CSS adl to opi converter so that XY graphs (medm Cartesian plots) are converted correctly.  I just tested that the following are now converted correctly and the BOY displays are correct:
XY plots with only a Y axis (no X axis)
XY plots with both a Y axis PV and an X axis PV
This is a screen shot of BOY configuration for an autoconverted XY plot with both X and Y axis PVs (look at Trace 0).
This is a screen shot of the live BOY display.  The X axis is the correct waveform record values.
Thanks for doing this Kay!
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Jörn Dreyer
Sent: Wednesday, April 18, 2018 6:58 AM
To: [email protected]
Subject: Re: CSS xy graph question
Hi Mark,
yes the NORD field is set correctly:
epics> dbpr XXX:cam1:WaveLengthArray_RBV
ASG:                BUSY: 0             DESC: Array of wavelength per bin
DISA: 0             DISP: 0             DISV: 1
NAME: XXX:cam1:WaveLengthArray_RBV                   NORD: 4000
SEVR: NO_ALARM      STAT: NO_ALARM      TPRO: 0             VAL: (nil)
epics> dbpr XXX:image1:ArrayData
ASG:                BUSY: 0             DESC:               DISA: 0
DISP: 0             DISV: 1             NAME: XXX:image1:ArrayData
NORD: 2048          SEVR: NO_ALARM      STAT: NO_ALARM      TPRO: 0
VAL: (nil)
If I do a caget it returns:
$> caget HIBEF:XFEL:cam1:WaveLengthArray_RBV
HIBEF:XFEL:cam1:WaveLengthArray_RBV 4000 340.32 340.702 341.084 341.467
341.849 342.231 342.614 342.996 343.378 343.76 344.142 344.524 344.906 345.288
345.669 ....
So that part works. If I add this PV as "X PV" to the XY graph widget, CSS has a problem and disconnects from the IOC nand reconnects to it aftera short moment.
Jörn
Am Mittwoch, 18. April 2018, 13:35:55 CEST schrieb Mark Rivers:
> Has the NORD field of that waveform record been set correctly?  What
> happens if you do caget on it?
> Mark
> ________________________________
> From: [email protected] <[email protected]> on
> behalf of Jörn Dreyer <[email protected]> Sent: Wednesday, April 18,
> 2018
> 4:31 AM
> Subject: CSS xy graph question
> Hi,
> I have a question regarding the XY graph widget in CS Studio.
> I want to define the x axis labels based on an array read from my
> areadetector driver. The PV is of type waveform with 4000 elements of
> type double and contains one value per bin.  If I put this record as
> "X PV", the widget shows an error and the message that the value of this PV is nil.
> The reason for this is, that the driver is universal for a class of
> spectrometers where every pixel in the sensor stands for a certain
> wavelength. Different devices have different ranges of wavelength they
> cover.
> Of course I could hard code the range, but then one needs to generate
> a separate OPI file for each type of device.
> What is the correct type for the PV that defines the x axis?
> Regards,
> Jörn Dreyer
Dr. Joern Dreyer
HIBEF DAQ + Controls
Institut für Strahlenphysik
Helmholtz-Zentrum Dresden - Rossendorf e.V
Abt. FWKX                Tel: +49 351 260 3263
                                   FAX: +49 351 260 3700
01314 Dresden        eMail: [email protected]
Helmholtz-Zentrum Dresden - Rossendorf e.V (HZDR) Bautzner Landstraße 400, 01328 Dresden
Vorstand: Prof. Dr. Dr. h. c. Roland Sauerbrey, Dr. Ulrich Breuer
Vereinsregister: VR 1693 beim Amtsgericht Dresden
CSS xy graph question Jörn Dreyer
Re: CSS xy graph question Mark Rivers
Re: CSS xy graph question Jörn Dreyer
Prev: Re: Request for OSI and RTEMS citations Arnold, Ned D.
Next: Re: Possible deadlock issue with asyn layer? Davis, Mark
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: CSS xy graph question Jörn Dreyer
Next: asyn4.33 compilation error on windows-64 Vishnu Patel
ANJ, 18 Apr 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
