1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Problem with autosave module making it crash at random basis.
To: "Abdalla Ahmad" <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 26 Apr 2018 11:29:10 +0000
Hi Abdalla,
Did you build everything from source (asyn, seq, etc.)
You do first get this warning:
Missing separate debuginfo for /home/control/epics/support/autosave/lib/linux-x86/libautosave.so
Try: yum --disablerepo='*' --enablerepo='*-debug*' install /usr/lib/debug/.build-id/9/6c3493510986245273cb0c308a16dc13e0aeee
But you then get this:
Reading symbols from /home/control/epics/support/autosave/lib/linux-x86/libautosave.so
...done.
The traceback now looks reasonable.
So I think it is working.  If you still have the autosave crash file you can run gdb on it as well.
I see that you are running very old versions of other modules as well asyn-4-18 is 6.5 years old.  Is there a reason you don't switch to more recent versions?
Sent: Thursday, April 26, 2018 12:33 AM
To: Mark Rivers; [email protected]
Subject: RE: Problem with autosave module making it crash at random basis.
OK I misunderstood your instructions.
I re-ran gdb as you instructed and I got the attached gdb output (not for the autosave crash). My question is, despite I got the source file where the crash happened, I still got missing debug info warnings for a lot of libraries. Should I try to rebuild everything with debug info integrated or this is sufficient?
Best Regards,
Abdalla.
-----Original Message-----
Sent: Thursday, April 26, 2018 8:18 AM
To: 'Mark Rivers' <[email protected]>; [email protected]
Gdb has been started like this
gdb './bin/linux-x86/ioc iocBoot/ioc/st.cmd' crash.xxxxxxx
Unfortunately no ,I did not try more recent version of autosave. The IOC crashed this time in an SNMP driver, so I will have to keep debugging this.
Best Regards,
Abdalla.
Sent: Wednesday, April 25, 2018 2:48 PM
To: Abdalla Ahmad <[email protected]>; [email protected]
gdb is printing this message near the beginning:
./bin/linux-x86/ioc iocBoot/ioc/st.cmd: No such file or directory.
It has none of your symbols.  Please send again showing the line where you started gdb.
Have you tried a more recent version of autosave?
Sent: Wednesday, April 25, 2018 12:52 AM
Hello Mark
Please find the attached output from gdb when running it with the core dump.
Best Regards,
Abdalla.
Sent: Wednesday, April 18, 2018 2:58 PM
Unfortunately I deleted the core dump. Once the IOC crash again I will send the complete output.
Abdalla.
> The core dump is generated but GDB could not show a backtrace and reported "missing separate debuginfo for the main executable file". Is it the case that the IOC should be built with debug symbols?
I have not seen that when building with the standard non-debug EPICS_HOST_ARCH of linux-x86_64.  It will warn that some system libraries don't have debug symbols, and some variables will be shown as "optimized out", but I have always been able to get a backtrace when it crashed.
Can you send the complete output when you start gdb and try to do a backtrace?
Sent: Wednesday, April 18, 2018 12:46 AM
Hi Mark
Best Regards,
Abdalla.
Sent: Sunday, April 08, 2018 4:01 PM
Hi Abdalla,
The latest autosave Makefile contains these lines:
# To enable autosaveBuild, use dbLoadRecordsHookRegister().  (Requires EPICS # base 3.14.12.5 or later.) USR_CFLAGS += -DDBLOADRECORDSHOOKREGISTER
Since you are running 3.14.12.3 I think you should try commenting out that USR_CFLAGS line.
With your older version of autosave your output showed that valgrind itself had crashed.  You should be able to get a traceback without valgrind, just by enabling core dumps.  Type the following commands:
On bash shell:
ulimit -c 10000000
or on csh shell:
limit core 1000000
Then run the IOC application.  When it crashes it will create a core.xxxxxx file.
Then run the Gnu debugger:
gdb path/to/your/IOC/executable core.xxxxxx
You need to provide the path to your IOC executable and replace core.xxxxxx with the name of the core file it just created.
Once you are in the debugger type:
backtrace
It will show a stack dump to where it crashed.
From: [email protected] <[email protected]> on behalf of Abdalla Ahmad <[email protected]>
Sent: Sunday, April 8, 2018 1:06 AM
To: [email protected]
Subject: Problem with autosave module making it crash at random basis.
Hi
One of our IOCs crashed and it appears to do so from time to time. I used valgrind on the IOC process and the attached file contains valgrind output right when the IOC crashed. The first 2 lines are the IOC shell output before the segmentation fault happened. I could not figure out whether the problem from the module sending something corrupted to the printf functions or the standard C library itself is somehow corrupted. I tried cloning the latest autosave version from github but the build failed. Build output is in the attached too.
OS: Scientific Linux 6.4 32-bit.
EPICS: 3.14.12.3
SynApps 5.6
Autosave 4.8
Best Regards,
Abdalla Ahmad
Control Engineer
SESAME
Allan, Jordan.
Tel: (+962-5) 3511348 , ext. 265
Fax: (+962-5) 3511423
Mob: (+962-7)88183296
www.sesame.org.jo<http://www.sesame.org.jo/>
Problem with autosave module making it crash at random basis. Abdalla Ahmad
Re: Problem with autosave module making it crash at random basis. Mark Rivers
RE: Problem with autosave module making it crash at random basis. Abdalla Ahmad
Prev: Re: NSLS-II Debian Repository in 2018 Ralph Lange
Next: RE: Problem with autosave module making it crash at random basis. Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Problem with autosave module making it crash at random basis. Abdalla Ahmad
Next: Re: Problem with autosave module making it crash at random basis. Michael Davidsaver
ANJ, 26 Apr 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
