1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Problem compiling and linking with asyn
Date: Wed, 16 May 2018 09:47:09 +0200
Hello folks,
I had a problem compiling and linking the asyn module on my OpenSuSE
Tumbleweed. It failed to link with error messages complaining about missing
symbols from lib asyn. The symbols all start with xdr_. Adding the libtirpc to
the SYS_LIBS solved the problem.
I confirmed with the SuSE team, that the change from glibc rpc code to
libtirpc was on purpose, as the glibc code does not support TCP/IP V6 as
transport protocol. The same should be true for other distributions.
So I guess that this library should be added to SYS_LIBS_Linux as it is
already done for cygwin.
Jörn
Re: Problem compiling and linking with asyn Mark Rivers
Prev: Re: PyEPICS timeout in jupyter Matt Newville
Next: Re: Problem compiling and linking with asyn Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
ANJ, 16 May 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
