1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Problem compiling and linking with asyn
To: Jörn Dreyer <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 16 May 2018 10:18:56 +0000
Hi Jörn,
I want to fix this for the next release of asyn.
Did you have to change anything to get it to find rpc.h at compile time?  The source code has this line:
#include <rpc/rpc.h>
I think that when using tirpc the path is tirpc/rpc/rpc/h.  Did you have to add /usr/include/tirpc to the include search paths?
From: [email protected] <[email protected]> on behalf of Jörn Dreyer <[email protected]>
Sent: Wednesday, May 16, 2018 2:47 AM
To: [email protected]
Subject: Problem compiling and linking with asyn
Hello folks,
I had a problem compiling and linking the asyn module on my OpenSuSE
Tumbleweed. It failed to link with error messages complaining about missing
symbols from lib asyn. The symbols all start with xdr_. Adding the libtirpc to
the SYS_LIBS solved the problem.
I confirmed with the SuSE team, that the change from glibc rpc code to
libtirpc was on purpose, as the glibc code does not support TCP/IP V6 as
transport protocol. The same should be true for other distributions.
So I guess that this library should be added to SYS_LIBS_Linux as it is
already done for cygwin.
Jörn
Re: Problem compiling and linking with asyn Jörn Dreyer
Prev: Problem compiling and linking with asyn Jörn Dreyer
Next: Re: Problem compiling and linking with asyn Jörn Dreyer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 16 May 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
