1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: PyEPICS timeout in jupyter
To: "Shen, Guobao" <[email protected]>
Date: Wed, 16 May 2018 16:34:17 -0500
On Wed, May 16, 2018 at 3:52 PM Shen, Guobao <[email protected]> wrote:
Hi Matt,
I double checked that, and found that when I import pvaccess, the behavior in terminal & in jupyter is same.
Oh, OK. I must have misunderstood your earlier reports.
The pvapy is a Python wrapper of pvaccess (EPICS7 protocol) developed by Sinisa.
It has its own interface for CA client, and does not use libca actually.
But its EPICS7 build does come with a version of libca.
I just happened to find the rare case.
My concern is that you were the first to find this problem, but won't be the last.   If "import pvaccess" is loading a CA shared library (and from your report, it sounds like it is), then there is the potential - actually a likliehood - for conflict with pypepics.
--Matt
PyEPICS timeout in jupyter Shen, Guobao
Re: PyEPICS timeout in jupyter Matt Newville
Re: PyEPICS timeout in jupyter Shen, Guobao
Prev: Error LNK2005 building Diamond's nullhttpd module on Windows J. Lewis Muir
Next: Re: Error LNK2005 building Diamond's nullhttpd module on Windows J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: PyEPICS timeout in jupyter Shen, Guobao
Next: Problem compiling and linking with asyn Jörn Dreyer
ANJ, 16 May 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
