1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Leica laser tracker integration with EPICS
To: "Hartman, Steven M." <[email protected]>, EPICS Tech Talk <[email protected]>
Date: Thu, 24 May 2018 08:32:15 +0200
Hej Steve,
for building the ESTIA neutron instrument (beamline) @ESS there has been
done some engineering work with an interferoemter and motion control.
They used an
Attocube IDS3010
The motion controller has been integrated into EPICS, using motorRecord.
The interferometer was not integrated into EPICS, mainly due to lack of time.
There was a mechanical test becnch, which was controlled by a python based
control system called NICOS2.
The engineers where quite happy with the complete setup, as far as I know.
For a more production-like setup I would push for a proper EPICS integration,
but we are not there yet.
Hopefully this answers some questions?
I can dig into the details if you want.
On 23/05/18 21:09, Hartman, Steven M. wrote:
For our engineering materials diffractometer instrument, we have been approached about the feasibility of integrating a laser tracker into the beam line EPICS system. The idea would be to use the laser tracker to measure position and compute six misalignment parameters. The misalignment parameters would be passed to the EPICS-based motion control system to correct positioning.
How anyone attempted this before? (I found a related query in tech-talk from 2016 but no response.)
The Survey & Alignment team suggests the Leica AT401 Laser Tracker [1] with the Spatial Analyzer (SA) software [2]. The SA software has a scripting interface (Measurement Plan) [3, page 927] which could be used to calculate the transformation from a measured misalignment to a motor move. The SA documentation [3, page 969] indicates that SA includes an OPC server.
[1] http://metrology.leica-geosystems.com/downloads123/m1/metrology/AT401/brochures-datasheet/Leica%20Absolute%20Tracker%20AT401%20-%20ASME%20specifications_en.pdf
[2] http://www.kinematics.com/spatialanalyzer/
[3] http://www.kinematics.com/ftp/SA/Install/Documentation/SA%20User%20Manual%202018.02.16.pdf
Leica laser tracker integration with EPICS Hartman, Steven M.
Prev: Re: EDM X/Y Plot segfaults Bruce Hill
Next: RE: EDM X/Y Plot segfaults Baily, Scott A
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: Leica laser tracker integration with EPICS Hartman, Steven M.
Next: caQtDM questions Baily, Scott A
ANJ, 24 May 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
