1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: caQtDM questions
To: EPICS Tech-Talk <[email protected]>
Date: Thu, 24 May 2018 16:35:54 +0000
I’ve been looking into caQtDM (I’ve used it for a few small projects already).  Some questions have come up, that don’t seem to be mentioned in the manual.
Is there a way for the waterfall plot to plot multiple scalar channels or only a single channel? I couldn’t seem to multiple channels to work, but I don’t know if it is supposed to. Could one construct a vector from several scalars using a soft variable?
Is there any documentation on PV specifications?
Soft pv’s appear to be an option, but I don’t see how to create them.  We have some PVs with {curly braces in their name (i.e., {}) caQtDM use these for specifying JSON strings to set the display rate.
If there a way to escape this or otherwise enclose it so that the entire thing can be considered part of the channel name?
EDM uses prefixes: EPICS\ for epics PVs (this is the default, but specifying this can work around parsing issues), LOC\ for local PVs, and CALC\ for calculations.
correspondence
Scott Baily
AOT-IC, MS H820
Los Alamos National Laboratory
Los Alamos, NM 87545
ph: (505) 606-2260
Prev: Re: EPICS CAS errors Dirk Zimoch
Next: ThorLabs motor driver Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Leica laser tracker integration with EPICS Torsten Bögershausen
ANJ, 24 May 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
