1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Stringin - asynOctedRead type how to set string length
To: Ralph Lange <[email protected]>, EPICS Tech Talk <[email protected]>
Date: Tue, 5 Jun 2018 13:42:43 +0000
Hi Ralph,
Thanks for the explanation.
Since there is no documentation can you or Andrew please explain:
- What is the advantage of the lsi and lso records vs waveform records for long strings?
- If I do caget on an lsi record that contains a long string do I need to use the -S option as I do for a waveform record holding a long string?
- Should support for the lsi and lso records be added to devAsynOctet?
Sent: Tuesday, June 5, 2018 8:24 AM
To: EPICS Tech Talk
Cc: Mark Rivers
Hi Mark,
You are right: these records have been introduced in 3.15 about 3 years ago (merged in October 2013, released as part of 3.15.0.2 a year later); the appropriate release note entry is missing. Must have been slipped, sorry for that.
I think I remember them being covered in status talks at Collaboration Meetings, though.
The wikified Record Reference Manual is explicitly covering the 3.14 release series, in which these records do not exist.
They are on the to-do list for the new, embedded record type documentation (check the *.dbd.pod files in the source tree), but have not been covered yet.
@all: the Collaboration Meeting next week will be your chance to talk about how to contribute to EPICS Base. Documentation is a nice field of opportunities.
Cheers,
~Ralph
On Tue, Jun 5, 2018 at 1:50 PM Mark Rivers <[email protected]<mailto:[email protected]>> wrote:
Hi Ralph,
When were the lsi and lso records introduced?  They do not seem to exist in 3.14.12.6.  I have searched the latest release notes for 3.14, 3.15, 3.16, and 7.0, and the first mention I see is in this:
Changes made between 3.15.3 and 3.15.4
New string input device support "getenv"
A new "getenv" device support for both the stringin and lsi (long string input) record types can be used to read the value of an environment variable from the IOC at runtime. See base/db/softIocExit.db for sample usage.
Note that this does not introduce the records, it just describes a new device support, and it only mentions the lsi record, not the lso.
The records are not documented in the record reference manual here:
https://wiki-ext.aps.anl.gov/epics/index.php/RRM_3-14
The git log indicates that the lsi record was added in 2012.
commit e01a428059d1c2217ec73660503c0ae81be0aa7b
Author: Andrew Johnson <[email protected]<mailto:[email protected]>>
Date:   Thu Nov 29 13:45:13 2012 -0600
    Added new Long String Input record type "lsi"
    With Soft Channel device support.
Since I was not aware that these records had been introduced I don't think they can be used with standard asyn device support?
Re: Stringin - asynOctedRead type how to set string length Ralph Lange
Modify checkbox value from a table widget Pilar Gil Jaldo
Stringin - asynOctedRead type how to set string length Pilar Gil Jaldo
Re: Stringin - asynOctedRead type how to set string length Mark Rivers
Re: Stringin - asynOctedRead type how to set string length Pilar Gil Jaldo
Prev: Re: Stringin - asynOctedRead type how to set string length Ralph Lange
Next: Re: Stringin - asynOctedRead type how to set string length Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 06 Jun 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
