Subject: |
Re: Why do EPICS Base startup scripts refer to non-depedencies? |
Andrew Johnson <[email protected]> |
To: |
Date: |
Fri, 22 Jun 2018 14:13:32 -0500 |
On 06/22/2018 01:12 PM, Ralph Lange wrote:
> I'd be ready to simply drop most (if not all).
> Personally I never used any of this (though I am aware that some
> portable automated builds use the script to determine the host
> architecture), and setting EPICS_HOST_ARCH is the only thing that is
> mandatory for all EPICS development and applies to all platforms.
Hmm, why don't we move the EpicsHostArch.pl script into src/tools so the
build system doesn't *need* there to be a startup directory at all and
it doesn't have to be installed.
I would still want to include some of the other files somewhere as a
starting point for site-specific scripts though. I have several
different versions of the win32.bat file for configuring Windows
development builds and IMHO something like this is pretty much essential
when developing on Windows, but I don't remember ever really using the
Site.* files (even though the last commit to them was mine, back in 2012).
> My 2 cts...
Invaluable, thanks! Unless there is other input I will work with Lewis
to implement that plan.
- Andrew
> On Fri, Jun 22, 2018 at 6:32 PM Andrew Johnson <[email protected]
> <mailto:[email protected]>> wrote:
> Hi Lewis,
> On 06/22/2018 10:50 AM, J. Lewis Muir wrote:
> > Why do the scripts in the EPICS Base 3.14, 3.15, and 3.16 startup
> > directory refer to things that are not dependencies of EPICS
> > Base (e.g., EPICS_EXTENSIONS, PSPRINTER for some extensions,
> > EPICS_DISPLAY_PATH and BROWSER for MEDM, ADTHOME for ADT, Exceed X11,
> > etc.)?
> Because they used to be managed by Janet Anderson who also handled
> maintenance for the EPICS Extensions tree, and none of the developers
> who are left have had the time to finish going through and cleaning them
> all up properly since she retired.
> I started developing code to install the contents of the startup
> directory to $(INSTALL_LOCATION)/startup a few months back, and I also
> did some clean-ups of the script files at the same time, but I haven't
> had time to finish that work yet.
> > IMO, the startup scripts should only refer to things related to EPICS
> > Base. For example, EPICS Base doesn't know anything about MEDM nor
> > should it. Therefore, <EPICS Base>/startup/Site.profile should not
> > set EPICS_DISPLAY_PATH or anything else that relates to MEDM. A much
> > better way would be for the EPICS Extensions package (currently known
> > as "Extensions build configure files") to provide a Site.profile, for
> > example, that can be edited to provide the environment or shell
> changes
> > required by the different extensions. Since MEDM, for example, is
> > an extension, then EPICS_DISPLAY_PATH and BROWSER should be set in
> > the Site.profile provided with the EPICS Extensions package, not the
> > Site.profile in EPICS Base.
> I agree with everything you wrote there. In my branch I cleaned out most
> of Janet's commented-out settings from the win32.bat file and also added
> a windows.bat file for windows-x64 architecture. My versions still have
> commented-out sections for Extensions and Exceed, but I don't have any
> problem with them being deleted as well.
> If you want to help clean up the startup directory I would be happy to
> work with you on this. Since these files are generally identical for all
> release series we only need to make changes to the earliest branch
> (currently 3.14, but without additional help the next Base-3.14.12.8
> release will be the last one we do from that branch). Changes made to
> 3.14 will get merged up to the later branches automatically.
> My work on installing into $(INSTALL_LOCATION)/startup was developed on
> the 3.15 branch and I don't think I would back-port that to 3.14 because
> it involves changes to the build rules which have evolved a bit more in
> the 3.15 and later series, but that won't affect the work to update the
> scripts themselves.
> EPICS is an open source development collaboration, and we depend on our
> users to help implement changes. I hope you will be able to find some
> time to contribute.
> Thanks,
> - Andrew
> Arguing for surveillance because you have nothing to hide is no
> different than making the claim, "I don't care about freedom of
> speech because I have nothing to say." -- Edward Snowdon
- Why do EPICS Base startup scripts refer to non-depedencies? J. Lewis Muir
- Re: Why do EPICS Base startup scripts refer to non-depedencies? Andrew Johnson
- Re: Why do EPICS Base startup scripts refer to non-depedencies? Ralph Lange
Re: A recent R3.15.5 Patch file Jeong Han Lee
<2018>
2025
2026
compilation error on pvData wrt epics base Jeong Han Lee
<2018>
2025
2026
