I am trying to compile the pvData w.r.t. EPICS base 3.15.5 and 3.16.1.
The procedure which I did is
1) install EPICS base with INSTALL_LOCATION (/epics/base-x.x.x)
2) install pvData (in source directory)
Then, it returns the following errors:
--- snip snip ----
ude -c ../../src/pv/pvdVersion.cpp
../../src/pv/pvdVersion.cpp: In function ‘void
epics::pvData::getVersion(epics::pvData::PVDataVersion*)’:
../../src/pv/pvdVersion.cpp:15:41: error: expected primary-expression
before ‘;’ token
ptr->major = EPICS_PVD_MAJOR_VERSION;
../../src/pv/pvdVersion.cpp:16:41: error: expected primary-expression
before ‘;’ token
ptr->minor = EPICS_PVD_MINOR_VERSION;
../../src/pv/pvdVersion.cpp:17:47: error: expected primary-expression
before ‘;’ token
ptr->maint = EPICS_PVD_MAINTENANCE_VERSION;
../../src/pv/pvdVersion.cpp:18:44: error: expected primary-expression
before ‘;’ token
ptr->devel = EPICS_PVD_DEVELOPMENT_FLAG;
/epics/base-3.15.5/configure/RULES_BUILD:237: recipe for target
'pvdVersion.o' failed
pvdVersion.d:1: *** [pvdVersion.o] Error 1
--- snip snip ----
The problem which I saw is pvdVersionNum.h, which doesn't have any
version number.
It turns out the ~/cfg/cfg/CONFIG_PVDATA_VERSION isn't included properly.
I forced to add the following line in CONFIG_SITE.local
-include $(TOP)/configure/CONFIG_PVDATA_VERSION
or
add the following line in pvData/configure/CONFIG
ifneq ($(TOP_CFG_CONFIGS),)
include $(TOP_CFG_CONFIGS)
endif
It properly is included and pvdVersionNum.h should have the proper
number.
When I will try to compile one by one instead of all, I expect the
same problems in most of EPICS V7 modules , because it uses the
core/master/cfg file
Please see the enclosed file for "make -c ./src install" log with and
without modifications.
Best,
Han
Without any modification
Entering src ....
--- snip snip ----
remake -C ./src install
Reading makefile 'Makefile'...
Reading makefile '../configure/CONFIG' (search path) (no ~ expansion)...
Reading makefile '../configure/RELEASE' (search path) (no ~ expansion)...
Reading makefile '../../RELEASE.local' (search path) (don't care) (no ~ expansion)...
Reading makefile '../../RELEASE..local' (search path) (don't care) (no ~ expansion)...
Reading makefile '../configure/RELEASE.local' (search path) (don't care) (no ~ expansion)...
Reading makefile '../configure/RELEASE..Common' (search path) (don't care) (no ~ expansion)...
Reading makefile '/epics/base-3.16.1/configure/CONFIG' (search path) (no ~ expansion)...
remake[1]: Entering directory '/home/jhlee/e3_v7/e3-pvData/pvDataCPP/src'
Reading makefile '/epics/base-3.16.1/configure/RELEASE' (search path) (don't care) (no ~ expansion)...
Reading makefile '/epics/base-3.16.1/configure/RELEASE.linux-x86_64' (search path) (don't care) (no ~ expansion)...
Reading makefile '/epics/base-3.16.1/configure/RELEASE.linux-x86_64.Common' (search path) (don't care) (no ~ expansion)...
Reading makefile '/epics/base-3.16.1/configure/CONFIG_COMMON' (search path) (no ~ expansion)...
Reading makefile '/epics/base-3.16.1/configure/CONFIG_FILE_TYPE' (search path) (no ~ expansion)...
Reading makefile '/epics/base-3.16.1/configure/CONFIG_BASE' (search path) (no ~ expansion)...
Reading makefile '/epics/base-3.16.1/configure/CONFIG_SITE' (search path) (no ~ expansion)...
Reading makefile '/epics/base-3.16.1/configure/CONFIG_BASE_VERSION' (search path) (no ~ expansion)...
Reading makefile '/epics/base-3.16.1/configure/os/CONFIG.linux-x86_64.Common' (search path) (no ~ expansion)...
Reading makefile '/epics/base-3.16.1/configure/os/CONFIG.UnixCommon.Common' (search path) (no ~ expansion)...
Reading makefile '/epics/base-3.16.1/configure/os/CONFIG_SITE.UnixCommon.Common' (search path) (don't care) (no ~ expansion)...
Reading makefile '/epics/base-3.16.1/configure/os/CONFIG_SITE.linux-x86_64.Common' (search path) (don't care) (no ~ expansion)...
Reading makefile '/home/jhlee/configure/CONFIG_USER' (search path) (don't care) (no ~ expansion)...
Reading makefile '/home/jhlee/configure/CONFIG_USER.linux-x86_64' (search path) (don't care) (no ~ expansion)...
Reading makefile '../configure/CONFIG_SITE' (search path) (no ~ expansion)...
Reading makefile '../../CONFIG_SITE.local' (search path) (don't care) (no ~ expansion)...
Reading makefile '../configure/CONFIG_SITE.local' (search path) (don't care) (no ~ expansion)...
Reading makefile '../configure/CONFIG_SITE.linux-x86_64.Common' (search path) (don't care) (no ~ expansion)...
Reading makefile '../src/misc/Makefile' (search path) (no ~ expansion)...
Reading makefile '../src/pv/Makefile' (search path) (no ~ expansion)...
Reading makefile '../src/factory/Makefile' (search path) (no ~ expansion)...
Reading makefile '../src/property/Makefile' (search path) (no ~ expansion)...
Reading makefile '../src/copy/Makefile' (search path) (no ~ expansion)...
Reading makefile '../src/pvMisc/Makefile' (search path) (no ~ expansion)...
Reading makefile '../src/json/Makefile' (search path) (no ~ expansion)...
Reading makefile '../configure/RULES' (search path) (no ~ expansion)...
Reading makefile '/epics/base-3.16.1/configure/RULES' (search path) (no ~ expansion)...
Reading makefile '/epics/base-3.16.1/configure/RULES_ARCHS' (search path) (no ~ expansion)...
Reading makefile '/home/jhlee/configure/RULES_USER' (search path) (don't care) (no ~ expansion)...
---- snip snip ---
Entering src with the pvData/configure/CONFIG modification as
endif
--- snip snip -----
Reading makefile '../cfg/CONFIG_PVDATA_VERSION' (search path) (no ~ expansion)...
--- snip snip -----
- Re: compilation error on pvData wrt epics base Johnson, Andrew N.
Re: A recent R3.15.5 Patch file Jeong Han Lee
<2018>
2025
2026
Re: Why do EPICS Base startup scripts refer to non-depedencies? Andrew Johnson
<2018>
2025
2026
