Hi Han
When you wrote “install pvData (in source directory)” what did you mean, and did you edit the pvData/configure/RELEASE file? I suspect you are not configuring the pvData module correctly.
Unless you’re using EPICS 7 or the fully bundled 4.7 release you need to treat each of the PVA modules as a regular support module, installing them in their own area and editing the configure/RELEASE files as appropriate (there should be comments in each file explaining what other modules they need to point to). It is also possible to set a value for INSTALL_LOCATION to a common directory in the modules’ CONFIG_SITE file, in which case you don’t have to worry about editing the RELEASE files.
- Andrew
Sent from my iPad
> On Jun 23, 2018, at 7:57 AM, Jeong Han Lee <[email protected]> wrote:
> Hi,
> I am trying to compile the pvData w.r.t. EPICS base 3.15.5 and 3.16.1.
> The procedure which I did is
> 1) install EPICS base with INSTALL_LOCATION (/epics/base-x.x.x)
> 2) install pvData (in source directory)
> Then, it returns the following errors:
> --- snip snip ----
> ude -c ../../src/pv/pvdVersion.cpp
> ../../src/pv/pvdVersion.cpp: In function ‘void epics::pvData::getVersion(epics::pvData::PVDataVersion*)’:
> ../../src/pv/pvdVersion.cpp:15:41: error: expected primary-expression before ‘;’ token
> ptr->major = EPICS_PVD_MAJOR_VERSION;
> ../../src/pv/pvdVersion.cpp:16:41: error: expected primary-expression before ‘;’ token
> ptr->minor = EPICS_PVD_MINOR_VERSION;
> ../../src/pv/pvdVersion.cpp:17:47: error: expected primary-expression before ‘;’ token
> ptr->maint = EPICS_PVD_MAINTENANCE_VERSION;
> ../../src/pv/pvdVersion.cpp:18:44: error: expected primary-expression before ‘;’ token
> ptr->devel = EPICS_PVD_DEVELOPMENT_FLAG;
> /epics/base-3.15.5/configure/RULES_BUILD:237: recipe for target 'pvdVersion.o' failed
> pvdVersion.d:1: *** [pvdVersion.o] Error 1
> --- snip snip ----
> The problem which I saw is pvdVersionNum.h, which doesn't have any version number.
> It turns out the ~/cfg/cfg/CONFIG_PVDATA_VERSION isn't included properly.
> I forced to add the following line in CONFIG_SITE.local
> -include $(TOP)/configure/CONFIG_PVDATA_VERSION
> or
> add the following line in pvData/configure/CONFIG
> ifneq ($(TOP_CFG_CONFIGS),)
> include $(TOP_CFG_CONFIGS)
> endif
> It properly is included and pvdVersionNum.h should have the proper number.
> When I will try to compile one by one instead of all, I expect the same problems in most of EPICS V7 modules , because it uses the core/master/cfg file
> Please see the enclosed file for "make -c ./src install" log with and without modifications.
> Best,
> Han
> <debug_cfg_include.txt>
- Re: compilation error on pvData wrt epics base Jeong Han Lee
- compilation error on pvData wrt epics base Jeong Han Lee
<2018>
2025
2026
<2018>
2025
2026
