1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: compilation error on pvData wrt epics base
To: "Johnson, Andrew N." <[email protected]>
Date: Sat, 23 Jun 2018 23:13:46 +0200
Hi Andrew,
  My BASE is in the following location:
$  tree -L 1 /epics/base-3.16.1/
/epics/base-3.16.1/
├── [root     4.0K]  bin
├── [root     4.0K]  configure
├── [root     4.0K]  db
├── [root     4.0K]  dbd
├── [root     4.0K]  html
├── [root      12K]  include
├── [root     4.0K]  lib
├── [root     4.0K]  startup
└── [root     4.0K]  templates
  And I added the RELEASE.local in pvDataCPP/configure with
EPICS_BASE=/epics/base-3.16.1/
I am using base-3.15.5 and 3.16.1, I don't need EPICS_LIBCOM variable in RELEASE, so I add only EPICS_BASE. That is only what I add into pvDataCPP.
  Do I miss something?
  Best,
  Han
On 06/23/2018 07:22 PM, Johnson, Andrew N. wrote:
Hi Han
When you wrote “install pvData (in source directory)” what did you mean, and did you edit the pvData/configure/RELEASE file? I suspect you are not configuring the pvData module correctly.
Unless you’re using EPICS 7 or the fully bundled 4.7 release you need to treat each of the PVA modules as a regular support module, installing them in their own area and editing the configure/RELEASE files as appropriate (there should be comments in each file explaining what other modules they need to point to). It is also possible to set a value for INSTALL_LOCATION to a common directory in the modules’ CONFIG_SITE file, in which case you don’t have to worry about editing the RELEASE files.
- Andrew
compilation error on pvData wrt epics base Jeong Han Lee
Re: compilation error on pvData wrt epics base Johnson, Andrew N.
Prev: Re: compilation error on pvData wrt epics base Johnson, Andrew N.
Next: pvData internal version doesn't match with "release tag" Jeong Han Lee
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 23 Jun 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
