1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: time series circular buffer
To: 'Hinko Kocevar' <[email protected]>, "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 25 Jun 2018 20:30:10 +0000
Hi Hinko,
I have implemented the change to the NDPluginStats plugin using the second method I suggested:
- Move the time series code out of the statistics plugin and have the statistics plugin send the time points as NDArrays to time series plugins.
This has the benefit of reducing the code by 240 lines while adding the functionality of the Circular Buffer mode.
The only downside is that it breaks backwards compatibility.  The names of the PVs for the time-series arrays are unchanged, but the PVs to control the time-series (start/stop, number of time points, etc.) are slightly changed.  I think this is probably OK because I doubt if these are widely used in client scripts.
I have put the new version in this branch of ADCore on Github: https://github.com/areaDetector/ADCore/tree/stats_time_series.  There is a pending pull-request for it.  If you (or anyone else) wants to test and comment that would be welcome.
Sent: Tuesday, June 19, 2018 8:28 AM
To: [email protected]; [email protected]; Mark Rivers <[email protected]>
Hi Mark,
sounds like both approaches might be acceptable. I guess it is about code duplication vs. number of different plugins one needs to get this feature, when it comes to deciding where to place this.
thanks,
hinko
Hinko Kocevar
Beam Diagnostics Engineer
European Spallation Source ERIC
P.O Box 176, SE-221 00 Lund, Sweden
Visiting address: Odarslövsvägen 113, 224 84 Lund
Mobile: +46-721-79 22 58
Phone:  +46-46-888 32 58
Web:    www.esss.se
On 2018-06-16 01:07:11+02:00 Mark Rivers wrote:
Hi Hinko,
I think it would be useful to be able to run the time series in circular buffer mode.  There are 2 ways this might be done:
- Add the code for circular buffer mode to the statistics plugin
I'm not sure which is best.
I have created an issue for this in ADCore.
-----Original Message-----
From: [email protected] <[email protected]> On Behalf Of Hinko Kocevar
Sent: Friday, June 15, 2018 3:55 AM
To: [email protected]; Tech-talk <[email protected]>
Subject: Re: time series circular buffer
Hi Tom,
thanks for the suggestion, I have not used this particular plugin so far. I'll give it a try!
Cheers,
Hinko
Sent: Friday, June 15, 2018 9:44:57 AM
To: Hinko Kocevar; Tech-talk
There is the NDPluginAttrPlot plugin which takes any numeric stamped NDAttributes (like the ones the NDPluginStats produces) and puts them in a circular buffer, periodically pushing the last N samples to a set of waveforms. We use it to plot arbitrary attributes against each other.
http://cars9.uchicago.edu/software/epics/NDPluginAttrPlot.html
Tom
&gt; -----Original Message-----
&gt; From: [email protected] <[email protected]> On
&gt; Behalf Of Hinko Kocevar
&gt; Sent: 15 June 2018 07:38
&gt; To: Tech-talk <[email protected]>
&gt; Subject: time series circular buffer
&gt;
&gt; Hi,
&gt;
&gt; in areaDetector NDPluginStats plugin I can get nice timeseries plots
&gt; for max, mean, min.
&gt; After the number of predefined points are collected the storing stops.
&gt; Is there a way to configure timeseries buffer as a circular buffer?
&gt; I've noticed that NDTimeSeries has this feature, but I'm failing to
&gt; find one in NDPluginStats.
&gt;
&gt; Thanks,
&gt;
&gt; Hinko Kocevar
&gt;
&gt; Beam Diagnostics Engineer
&gt; European Spallation Source ERIC
&gt; P.O Box 176, SE-221 00 Lund, Sweden
&gt; Visiting address: Odarslövsvägen 113, SE-224 84 Lund , Sweden
&gt;
&gt; Mobile: +46-721-79 22 58
&gt; Phone:  +46-46-888 32 58
&gt;
&gt; E-mail: [email protected]
&gt; Web:    www.esss.se
</[email protected]></[email protected]></[email protected]></[email protected]></[email protected]>
Re: time series circular buffer Hinko Kocevar
RE: time series circular buffer [email protected]
RE: time series circular buffer Mark Rivers
RE: time series circular buffer Hinko Kocevar
Prev: pvData internal version doesn't match with "release tag" Jeong Han Lee
Next: Question about RDB Channel archiver engine be used for the waveform channels lzf neu
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: time series circular buffer Hinko Kocevar
Next: Re: time series circular buffer Hinko Kocevar
ANJ, 26 Jun 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
