Hi Hinko,
The ASCII code for ‘*’ is 42, so you can do
dbpf <record> ‘*’
I admit this isn’t a particularly general solution, but in an emergency...
Our command-line commands were originally designed for the VxWorks shell which doesn’t allow for large numbers of parameters. Improvements welcomed!
- Andrew
Sent from my iPad
> On Jun 28, 2018, at 7:12 AM, Hinko Kocevar <[email protected]> wrote:
> Hi,
> at the moment I can use dbpf to write array of char values (ASCII) to waveform.
> epics> dbpf FEB-030Row:PBI-EVR-030:SoftSeq0-EvtCode-SP dodo
> DBR_UCHAR[5]: 100 0x64 111 0x6f
> 100 0x64 111 0x6f
> 0 0x0
> OTOH, if I want to write '42', as an integer, to index 0 of waveform I do not get expected results.
> epics> dbpf FEB-030Row:PBI-EVR-030:SoftSeq0-EvtCode-SP 42
> DBR_UCHAR[3]: 52 0x34 50 0x32
> 0 0x0
> Any way to get 42 into the waveform with current iocsh facilities?
> Thanks,
> Hinko
- RE: dbpf to waveform Hinko Kocevar
- dbpf to waveform Hinko Kocevar
<2018>
2025
2026
<2018>
2025
2026
