1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Failed caput not notified when using ca_array_put_callback
To: "tech-talk ([email protected])" <[email protected]>
Date: Mon, 9 Jul 2018 13:50:39 +0000
Here is a very curious issue that I've just stumbled across: asynchronous caput failure is reported, synchronous caput failure is hidden.
I have a PV that (depending on the state of the IOC) is rejecting caputs; it does this by returning 1 from the appropriate record processing function.  Using the command line caput tool I observe a strange discrepancy, watch:
1. asynchronous put
$ caput TS-DI-TMBF-02:MEM:CAPTURE_S 0
Old : TS-DI-TMBF-02:MEM:CAPTURE_S
CA.Client.Exception...............................................
    Warning: "Channel write request failed"
    Context: "op=1, channel=TS-DI-TMBF-02:MEM:CAPTURE_S, type=DBR_DOUBLE, count=1, ctx="TS-DI-TMBF-02:MEM:CAPTURE_S""
    Source File: ../oldChannelNotify.cpp line 159
New : TS-DI-TMBF-02:MEM:CAPTURE_S
    Current Time: Mon Jul 09 2018 14:14:03.307001699
2. synchronous put
$ caput -c -w 1 TS-DI-TMBF-02:MEM:CAPTURE_S 0
Note that in case (1) we have asynchronous notification of the put failure ... which I presume we get to see because caput follows up with a caget giving time for the failure to be returned.
On the other hand, in case (2) no error is reported.
Repeating this test with other tools, it seems that the callback called by ca_array_put_callback is always called with args.status == ECA_NORMAL, and I can see no other channel for notifying failure.
This is odd, and I'm surprised to have stumbled across this after so many years.  I'm sure this is a defect somewhere, but am afraid I can't see on which side of the wire it sits.
RE: Failed caput not notified when using ca_array_put_callback [email protected]
Prev: Re: Is EPICS license GPL-compatible? Carlos Pascual
Next: RE: 'assert (pca->pgetNative)' failed in ../dbCa.c [email protected]
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: New release of ADProsilica Mark Rivers
Next: RE: Failed caput not notified when using ca_array_put_callback [email protected]
ANJ, 10 Jul 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
