1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Failed caput not notified when using ca_array_put_callback
To: "tech-talk ([email protected])" <[email protected]>
Date: Tue, 10 Jul 2018 09:36:08 +0000
> Here is a very curious issue that I've just stumbled across: asynchronous
> caput failure is reported, synchronous caput failure is hidden.
I have managed to pin this down a bit further by running wireshark with Michael Davidsaver's nice caproto plugin, and it appears that the IOC (not the client library) is responsible for hiding the synchronous caput failure.
Below is a transcript of two caput sessions.  In the first exchange we send CA_PROTO_WRITE and receive CA_PROTO_ERROR in response, in the second we send and receive CA_PROTO_WRITE_NOTIFY with ECA_NORMAL in the response.
This is tested with EPICS 3.14.12.3, so maybe this has been fixed in a more recent version, but given the cryptic character of this issue maybe not.
Asynchronous
Client -> IOC
    Command: Write (0x0004)
    Payload Size: 8
    DBR Type: DOUBLE (6)
    Data Count: 1
    Operation ID: 1
    Server Channel ID: 519
    Value: 0
IOC -> Client
    Command: Error (0x000b)
    Payload Size: 48
    Data Type: 0x0000
    Data Count: 0
    Client Channel ID: 1
    Status: ECA_PUTFAIL (0x000000a0)
    Channel Access
        Payload Size: 8
        Data Type: 0x0006
        Data Count: 1
        Param 1: 0x00000207
        Param 2: 0x00000001
    Error Message: TS-DI-TMBF-02:MEM:CAPTURE_S
Synchronous
Client -> IOC
    Command: Write Notify (0x0013)
    Payload Size: 8
    Data Count: 1
    Operation ID: 3
    Server Channel ID: 520
    Value: 0
IOC -> Client
    Payload Size: 0
    Data Count: 1
    Operation ID: 3
    Status: ECA_NORMAL (0x00000001)
RE: Failed caput not notified when using ca_array_put_callback michael.abbott--- via Tech-talk
Failed caput not notified when using ca_array_put_callback [email protected]
Prev: Network errors on a 6100 (running RTEMS 4.10.2) Ricardo Cardenes
Next: RE: Network errors on a 6100 (running RTEMS 4.10.2) Mark Engbretson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Failed caput not notified when using ca_array_put_callback [email protected]
Next: RE: Failed caput not notified when using ca_array_put_callback michael.abbott--- via Tech-talk
ANJ, 16 Jul 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
