Subject: |
Network errors on a 6100 (running RTEMS 4.10.2) |
Ricardo Cardenes <[email protected]> |
To: |
Talk EPICS Tech <[email protected]> |
Date: |
Mon, 9 Jul 2018 16:01:12 -1000 |
I got a 6100 that was booting correctly, but then refusing to mount the file system over NFS (and complaining also about NTP).
If found an old message that matched my problem, and an answer suggesting to force the speed in the switch (down to 100Mbps) instead of letting the board auto-negotiate it. Till Straumann replied that this should not be necessary, as those boards are known to be working properly with Gigabit Ethernet, but this actually worked for me (!!)
Has anyone else experienced the same problem? Any hints/solutions?
Cheers, Ricardo
- RE: Network errors on a 6100 (running RTEMS 4.10.2) Mark Engbretson
areaDetector R3-3-2 released Mark Rivers
RE: Failed caput not notified when using ca_array_put_callback [email protected]
<2018>
2025
2026
<2018>
2025
2026
ANJ, 10 Jul 2018 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
