1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: areaDetector R3-3-2 released
Date: Mon, 9 Jul 2018 17:12:05 +0000
New releases of the following areaDetector modules are now available.
areaDetector R3-3-2
ADCore R3-3-2
These are from the R3-3-2 release notes for areaDetector:
* configure/EXAMPLE_CONFIG_SITE.local
Added new WITH_QSRV variable. 3.14.12 supports pvAccess but does not support qsrv. By setting WITH_PVA=YES and WITH_QSRV=NO IOCs can be built with pvAccess support but without qsrv support.
These are from the R3-3-3 release notes for ADCore:
* Changed so that qsrv dbd and lib files are only included if WITH_QSRV=YES. Previously they were included if WITH_PVA=YES. However base 3.14.12 supports WITH_PVA but does not support qsrv. This allows WITH_PVA=YES to be used on 3.14.12 as long as WITH_QSRV=NO.
The home page is here:
http://cars.uchicago.edu/software/epics/areaDetector.html
The top-level documentation is here:
http://cars.uchicago.edu/software/epics/areaDetectorDoc.html
Installation instructions are here:
https://github.com/areaDetector/areaDetector/blob/master/INSTALL_GUIDE.md
areaDetector release notes are here:
https://github.com/areaDetector/areaDetector/blob/master/RELEASE.md
ADCore release notes are here:
https://github.com/areaDetector/ADCore/blob/master/RELEASE.md
Prev: RE: 'assert (pca->pgetNative)' failed in ../dbCa.c [email protected]
Next: Network errors on a 6100 (running RTEMS 4.10.2) Ricardo Cardenes
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Failed caput not notified when using ca_array_put_callback michael.abbott--- via Tech-talk
ANJ, 16 Jul 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
