1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Network errors on a 6100 (running RTEMS 4.10.2)
To: 'Ricardo Cardenes' <[email protected]>, 'Talk EPICS Tech' <[email protected]>
Date: Tue, 10 Jul 2018 07:40:14 -0500
Have you tried plugging the 6100 into a dumb hub or a switch?
I know that this seems odd, but at various times noise or other environmental variables have caused almost exactly the problem that you have, and sticking a dumb hub between the 61000 and wherever you normally plug into the network sometimes makes the issue go away.
From: [email protected] <[email protected]> On Behalf Of Ricardo Cardenes
Sent: Monday, July 9, 2018 9:01 PM
To: Talk EPICS Tech <[email protected]>
Subject: Network errors on a 6100 (running RTEMS 4.10.2)
I got a 6100 that was booting correctly, but then refusing to mount the file system over NFS (and complaining also about NTP).
If found an old message that matched my problem, and an answer suggesting to force the speed in the switch (down to 100Mbps) instead of letting the board auto-negotiate it. Till Straumann replied that this should not be necessary, as those boards are known to be working properly with Gigabit Ethernet, but this actually worked for me (!!)
Has anyone else experienced the same problem? Any hints/solutions?
Cheers,
Ricardo
Network errors on a 6100 (running RTEMS 4.10.2) Ricardo Cardenes
Prev: RE: Failed caput not notified when using ca_array_put_callback [email protected]
Next: MEDM compilation on Ubuntu 16.04 Alper Kinaci
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Network errors on a 6100 (running RTEMS 4.10.2) Ricardo Cardenes
ANJ, 18 Jul 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
