1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Rotating Image in NDPluginPva plugin
To: "Rivers, Mark L." <[email protected]>, "J. Lewis Muir" <[email protected]>
Cc: Tech-Talk <[email protected]>
Date: Wed, 18 Jul 2018 16:29:11 +0000
Great, it works.
Guobao
On 7/18/18, 11:10 AM, "Mark Rivers" <[email protected]> wrote:
    You need to tell the NDPluginPva to get its array from the NDPluginTransform, rather than directly from the detector.  This is the ArrayPort PV.
    Sent: Wednesday, July 18, 2018 11:07 AM
    To: Mark Rivers; J. Lewis Muir
    Cc: Tech-Talk
    Hi Mark, Lewis,
    I rotated the image 90 deg with NDPluginTransform.
    But I did not see any change in ImageJ.
    Did I miss anything?
    Guobao
    ?On 7/18/18, 10:35 AM, "Mark Rivers" <[email protected]> wrote:
        Hi Guobao,
        Lewis is correct.  The NDPluginPva has never had rotation capability, you should use the NDPluginTransform for that.
        From: [email protected] <[email protected]> on behalf of J. Lewis Muir <[email protected]>
        Sent: Wednesday, July 18, 2018 10:18 AM
        To: Shen, Guobao
        Cc: Tech-Talk
        On 07/18, Shen, Guobao wrote:
        > Hi,
        > I found there was an old discussion to rotate image by 90 degree (or 270 degree) in areaDetector NDPluginPva plugin,
        > https://epics.anl.gov/tech-talk/2017/msg00454.php
        > Is that function available to use now?
        > Thanks,
        > Guobao
        Can't you use NDPluginTransform to rotate, and then feed that to
        NDPluginPva?
        Lewis
Rotating Image in NDPluginPva plugin Shen, Guobao
Re: Rotating Image in NDPluginPva plugin J. Lewis Muir
Re: Rotating Image in NDPluginPva plugin Mark Rivers
Re: Rotating Image in NDPluginPva plugin Shen, Guobao
Prev: Re: MEDM compilation on Ubuntu 16.04 Bob Soliday
Next: Re: Rotating Image in NDPluginPva plugin Michael Davidsaver
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Rotating Image in NDPluginPva plugin Mark Rivers
ANJ, 18 Jul 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
