1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Delta Tau motor control problem
To: "[email protected]" <[email protected]>, Torsten Bögershausen <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 3 Aug 2018 11:32:11 -0500
On 08/03/2018 08:26 AM, [email protected] wrote:
For 'dumb mode' I would like the motor record to always send the commands that the user requests and only send those commands.
You aren't required to use the motor record to communicate with model 3 asyn motor drivers. It is possible to use generic EPICS records with asyn device support to access the various asyn motor parameters, which would effectively be a 'dumb mode'.
Kevin
Re: Delta Tau motor control problem [email protected]
Fwd: Re: Delta Tau motor control problem Mark Davis
Re: Re: Delta Tau motor control problem [email protected]
Re: Delta Tau motor control problem Torsten Bögershausen
Prev: Fw: Delta Tau motor control problem [email protected]
Next: Re: DBE_PROPERTY and Gateway Shankar, Murali
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Delta Tau motor control problem [email protected]
Next: Re: Delta Tau motor control problem [email protected]
ANJ, 06 Aug 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
