Sorry for being silent - I had to attend to other matters...
Andrew's earlier post
"My assumption is that they're wanting direct access to a large block of
data without copying it..."
is right on the spot.
From my point of view either variant
dbGetPdbAddrFromLink(DBLINK *, DBADDR*);
doDbAddr(struct link *plink, dbLinkDbAddrCallback rtn,
void *priv);
with either
typedef long (*dbLinkDbAddrCallback)(const dbAddr *paddr, void *priv);
or
typedef long (*dbLinkDbAddrCallback)(void *pBuffer, int dbfType, long nelements, void *priv);
would be acceptable. If you really want to hide DBADDR then the last
variant would probably be preferable.
The very first option (dbGetPdbAddrFromLink)
would pretty much restore 3.14 which I thought you wanted to avoid?
I'd also argue that (isn't the number of elements also mutable across
locked operations ?) since there are already
long
dbGetNelements(const struct link*, long *);
and
int
dbGetLinkDBFType(const struct link*);
that simply adding
int
dbGetLinkBufPtr(const struct link *, void **);
could be enough since the user should know that all the
results are only valid while he/she holds the lock
(a respective comment in dbLink.h might be a good idea).
Thanks for looking into this
- Till
On 08/06/2018 11:26 AM, Michael Davidsaver wrote:
On 08/06/2018 10:01 AM, Andrew Johnson wrote:
On 08/06/2018 11:15 AM, Michael Davidsaver wrote:
On 08/04/2018 08:43 AM, Johnson, Andrew N. wrote:
I would be wary of just handing out the dbAddr* pointer though,
since the link could get changed without any notice, so I would
like to add a little more enforcement. Some link types could even
use this to provide access to their raw data buffers, so I’m
wondering about an API like doLocked() where the caller gives us a
function pointer which we call back with a dbAddr*.
My thinking has been something like:
int dbGetPdbAddrFromLink(DBLINK *plink, DBADDR *pout);
which would be used like
DBLINK *plink = ...;
DBADDR addr;
dbScanLock(plink->precord);
if(dbGetPdbAddrFromLink(plink, &addr)==0) {
// do something with addr
Though this would look different in the context of an aSub function,
the point is that this avoids returning a pointer to the internal
struct dbAddr by making a copy. This copy remains valid in
perpetuity, although the assurance that both records are covered by
the same lock expires as soon as the source record is unlocked.
I don't believe it's legal to call any current dbLink.h function unless
you're already holding the lock for the record that owns that link, so
IMO your dbScanLock() should be superfluous.
Yup, I was just being explicit.
Copying a dbAddr also copies its pfield member pointer. If the target
field of the link is using double-buffering that pointer isn't going to
be valid after the next buffer-switch, but your API doesn't indicate that.
True.
That's why I'd prefer to have the user provide a callback function; it
should be obvious that the information provided is only valid for the
duration of the call (we can also avoid making a copy of the dbAddr):
long dbLinkDoDbAddr(struct link *plink, dbLinkDbAddrCallback rtn,
void *priv);
I don't see how this is significantly different than copying the dbAddr.
As you point out, the complexity comes from handling dbAddr*. And this
can only be avoided by extracting the relevant information. Of course
this requires a better idea of what "relevant" is for Till.
If we want to go the callback route, maybe the better way to handle this
is to take the signature of lset::getValue() as a starting point? Passing
a triple of buffer pointer, DBF code, and element count.
This would call a new lset routine which only DB links would implement;
other link types would just return an error (unless they are willing to
give out access to their local buffer for the link data, in which case
they could create a dbAddr for that buffer).
Can we defer talk of an API change until there is a second link type which
wants to do this? DB links are already handled as a special case in other
ways (locking).
In dbDbLink.c the implementation is just:
static long doDbAddr(struct link *plink, dbLinkDbAddrCallback rtn,
void *priv)
DBADDR *paddr = (DBADDR *) plink->value.pv_link.pvt;
return rtn(paddr, priv);
Till, nothing more is likely to happen on this topic without your
feedback, would this API be sufficient to implement what you need?
I'm not planning to take any immediate action.
- Re: dbGetPdbAddrFromLink dropped from 3.15 again Johnson, Andrew N.
- dbGetPdbAddrFromLink dropped from 3.15 again Till Straumann
- Re: dbGetPdbAddrFromLink dropped from 3.15 again Michael Davidsaver
- Re: dbGetPdbAddrFromLink dropped from 3.15 again Andrew Johnson
Data browser web tool Vishnu Patel
<2018>
2025
2026
<2018>
2025
2026
