1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Makefile question
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Mon, 10 Dec 2018 08:59:46 +0100
On Mon, 10 Dec 2018 at 05:39, Johnson, Andrew N. via Tech-talk <[email protected]> wrote:
I haven’t checked the build rules yet, but I wonder if your bitshuffle_hdf5_LIBS setting is wrong, shouldn’t that be set to bitshuffle instead of bitshuffle_hdf5? It currently looks like you’re asking the build to link that library against itself. I suspect that if you fix that the build system may do what you want automatically.
@Andrew: As far as I see, there's no underscore in that setting. So, bitshuffle_hdf5 is supposed to be linked against two libraries, bitshuffle and hdf5, which makes sense. (And matches the requirement to build bitshuffle first.)
What I noticed is that the WITH_HDF5 clause resets LIBRARY_IOC to be bitshuffle_hdf5 instead of bitshuffle. I would assume that this should rather be added using '+=' ... at least that's how it is mentioned in the AppDevelopers (in 4.4.4 "Simple Makefile examples").
Cheers,
~Ralph
On Dec 9, 2018, at 7:49 AM, Mark Rivers via Tech-talk <[email protected]> wrote:
I have a Makefile that builds 2 libraries.  Library A must be built before library B, because B depends on A (important for dynamic builds on Windows).  What is the rule I need to add to force A to be built before B?
This is the actual Makefile.  bitshuffle_hdf5.lib must be built after bitshuffle.lib.
TOP=../..
include $(TOP)/configure/CONFIG
#  ADD MACRO DEFINITIONS AFTER THIS LINE
ifeq ($(WITH_BITSHUFFLE),YES)
  ifeq ($(BITSHUFFLE_EXTERNAL),NO)
    LIBRARY_IOC = bitshuffle
    BITSHUFFLE = $(TOP)/supportApp/bitshuffleSrc
    USR_CFLAGS_Linux += -std=c99
    USR_CFLAGS_WIN32 += -DLZ4_DLL_EXPORT=1
    INC += bitshuffle.h
    INC += bitshuffle_core.h
    INC += bshuf_h5filter.h
    bitshuffle_SRCS += bitshuffle.c
    bitshuffle_SRCS += bitshuffle_core.c
    bitshuffle_SRCS += iochain.c
    SRC_DIRS += $(BITSHUFFLE)/lz4
    INC += lz4.h
    bitshuffle_SRCS += lz4.c
    ifeq ($(WITH_HDF5),YES)
        LIBRARY_IOC = bitshuffle_hdf5
        bitshuffle_hdf5_SRCS += bshuf_h5filter.c
        bitshuffle_hdf5_SRCS += bshuf_h5plugin.c
        bitshuffle_hdf5_LIBS += bitshuffle hdf5
    endif # ($(WITH_HDF5),YES)
  endif # ($(BITSHUFFLE_EXTERNAL),NO)
endif # ($(WITH_BITSHUFFLE),YES)
include $(TOP)/configure/RULES
#  ADD RULES AFTER THIS LINE
I tried this rule, which would only work on Windows, but it did not work.
bitshuffle_hdf5.lib: bitshuffle.lib
Re: Makefile question Mark Rivers via Tech-talk
Re: Makefile question Johnson, Andrew N. via Tech-talk
Prev: Re: Makefile question Johnson, Andrew N. via Tech-talk
Next: Re: Makefile question Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
ANJ, 10 Dec 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
