I verified my suspicion. I deleted the base-7.0.2/html directory and did "make clean" on the Pilatus architecture.
I then got the perl errors:
gse-pilatus1 epics-devel/base-7.0.2> make -sj4
Can't locate Pod/Simple/HTML.pm in @INC (@INC contains: /usr/lib/perl5/5.8.8/x86_64-linux-thread-multi /usr/lib/perl5/5.8.8 /usr/lib/perl5/site_perl/5.8.8/x86_64-linux-thread-multi /usr/lib/perl5/site_perl/5.8.8 /usr/lib/perl5/site_perl /usr/lib/perl5/vendor_perl/5.8.8/x86_64-linux-thread-multi /usr/lib/perl5/vendor_perl/5.8.8 /usr/lib/perl5/vendor_perl .) at ../../../src/tools/podToHtml.pl line 15.
BEGIN failed--compilation aborted at ../../../src/tools/podToHtml.pl line 15.
make[3]: *** [../O.Common/EPICS/Path.html] Error 2
make[3]: *** Waiting for unfinished jobs....
make[3]: *** [../O.Common/EPICS/Readfile.html] Error 2
make[3]: *** [../O.Common/EPICS/Getopts.html] Error 2
make[2]: *** [install.linux-x86_64-gcc42] Error 2
make[1]: *** [tools.install] Error 2
make: *** [src.install] Error 2
gse-pilatus1 epics-devel/base-7.0.2> exit
By running "make" again on Centos7 it built the HTML files and then I was able to build OK on the Pilatus machine.
-----Original Message-----
Sent: Friday, December 21, 2018 9:19 AM
To: 'Peterson, Kevin M.' <[email protected]>
Cc: [email protected]; Woods, Russell <[email protected]>
Subject: RE: FW: Error compiling EPICS base-7.0.x on OpenSUSE 10.3
My system has no perl environment variables set:
/home/epics> printenv | grep PERL
/home/epics>
I just realized what one difference could be. I am building all architectures in the same tree on a Centos 7 system. I built the linux-x86-64 architecture first, which is the Centos 7 EPICS_HOST_ARCH. I then built the older linux-x86_64-gcc42 architecture, which is the one for the Pilatus. Since the html documentation had already been built on the newer architecture "make" was probably smart enough to not try to build it again on the old architecture. Thus I may have the problem but would only see it if I built first on linux-x86_64-gcc42.
Sent: Friday, December 21, 2018 8:51 AM
To: Mark Rivers <[email protected]>
Subject: Re: FW: Error compiling EPICS base-7.0.x on OpenSUSE 10.3
Have you confirmed that the perl environment variables are the same?
Kevin
On 12/20/18 4:01 PM, Mark Rivers via Tech-talk wrote:
> This thread moved off tech-talk for a while, but I'm putting it back
> in case someone has ideas.
> My system and Russ' appear to be the same, but he gets the error and I
> don't.
> Mark
- Re: Error compiling EPICS base-7.0.x on OpenSUSE 10.3 Johnson, Andrew N. via Tech-talk
- Error compiling EPICS base-7.0.x on OpenSUSE 10.3 Woods, Russell via Tech-talk
- RE: Error compiling EPICS base-7.0.x on OpenSUSE 10.3 Mark Rivers via Tech-talk
- FW: Error compiling EPICS base-7.0.x on OpenSUSE 10.3 Mark Rivers via Tech-talk
- Re: FW: Error compiling EPICS base-7.0.x on OpenSUSE 10.3 Peterson, Kevin M. via Tech-talk
- RE: FW: Error compiling EPICS base-7.0.x on OpenSUSE 10.3 Mark Rivers via Tech-talk
Re: Stream fails on windows-x64 against base-7.0.2 Zimoch Dirk (PSI) via Tech-talk
<2018>
2025
2026
<2018>
2025
2026
