Sorry for the delay, I’ve been traveling (and my wife says I’m on holiday and shouldn’t be working anyway)...
> On Dec 21, 2018, at 9:29 AM, Mark Rivers via Tech-talk <[email protected]> wrote:
> I verified my suspicion. I deleted the base-7.0.2/html directory and did "make clean" on the Pilatus architecture.
> I then got the perl errors:
> gse-pilatus1 epics-devel/base-7.0.2> make -sj4
> Can't locate Pod/Simple/HTML.pm in @INC (@INC contains: /usr/lib/perl5/5.8.8/x86_64-linux-thread-multi /usr/lib/perl5/5.8.8 /usr/lib/perl5/site_perl/5.8.8/x86_64-linux-thread-multi /usr/lib/perl5/site_perl/5.8.8 /usr/lib/perl5/site_perl /usr/lib/perl5/vendor_perl/5.8.8/x86_64-linux-thread-multi /usr/lib/perl5/vendor_perl/5.8.8 /usr/lib/perl5/vendor_perl .) at ../../../src/tools/podToHtml.pl line 15.
> BEGIN failed--compilation aborted at ../../../src/tools/podToHtml.pl line 15.
Apparently Perl 5.8.8 didn’t come with the Pod::Simple::HTML module which I use to convert POD (Plain Old Documentation) into HTML files in the EPICS INSTALL_HTML directory, it first appeared in Perl 5.10 (which was released in December 2007). In an earlier response Matt Newville gave explicit instructions on how to install the module, which should work. Mark’s solution of first building for a different host architecture which has that Perl module is your best workaround if you can’t install it using cpan or some equivalent such as the OpenSUSE package management system.
- Andrew
- RE: Error compiling EPICS base-7.0.x on OpenSUSE 10.3 Mark Rivers via Tech-talk
- Error compiling EPICS base-7.0.x on OpenSUSE 10.3 Woods, Russell via Tech-talk
- FW: Error compiling EPICS base-7.0.x on OpenSUSE 10.3 Mark Rivers via Tech-talk
- Re: FW: Error compiling EPICS base-7.0.x on OpenSUSE 10.3 Peterson, Kevin M. via Tech-talk
- RE: FW: Error compiling EPICS base-7.0.x on OpenSUSE 10.3 Mark Rivers via Tech-talk
RE: Stream fails on windows-x64 against base-7.0.2 Freddie Akeroyd - UKRI STFC via Tech-talk
<2018>
2025
2026
<2018>
2025
2026
