Hi Gerry, On Thu, Jan 17, 2019 at 9:32 AM Gerry Swislow <[email protected]> wrote: Hi Matt, - Gerry Yes, it does look like a problem with building epics base on MacOS (at least with 10.14) with Apple-supplied Perl (5.18). I get the same error as you (perl's XS tool cannot find its EXTERN.h) trying to build both base-3.16.2 and base-7.0.2 with Apple-supplied Perl (/usr/bin/perl). I can build both base-3-16.2 and base-7.0.2 using perl (5.26) from MacPorts. Using that perl which got installed to /opt/local/bin/perl), the section of the build looks like this: /Applications/Xcode.app/Contents/Developer/usr/bin/make -C O.darwin-x86 -f ../Makefile TOP=../../.. \ T_A=darwin-x86 install rm -f Cap5.c Cap5.c_new perl -CSD /opt/local/bin/xsubpp -typemap /opt/local/lib/perl5/5.26/ExtUtils/typemap ../Cap5.xs > Cap5.c_new && mv Cap5.c_new Cap5.c perl -CSD /Users/Newville/local/epics/base-7.0.2/bin/darwin-x86/mkmf.pl -m Cap5.d -I. -I../O.Common -I. -I. -I.. -I/Users/Newville/local/epics/base-7.0.2/include/compiler/clang -I/Users/Newville/local/epics/base-7.0.2/include/os/Darwin -I/Users/Newville/local/epics/base-7.0.2/include -I/Users/Newville/local/epics/base-7.0.2/include/compiler/clang -I/Users/Newville/local/epics/base-7.0.2/include/os/Darwin -I/Users/Newville/local/epics/base-7.0.2/include -I/opt/local/lib/perl5/5.26/darwin-thread-multi-2level/CORE Cap5.o Cap5.c cc -DUNIX -Ddarwin -O3 -g -Wall -fno-common -DPERL_DARWIN -mmacosx-version-min=10.13 -pipe -Os -fno-strict-aliasing -fstack-protector-strong -I/opt/local/include -DPERL_USE_SAFE_PUTENV -arch x86_64 -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I/Users/Newville/local/epics/base-7.0.2/include/compiler/clang -I/Users/Newville/local/epics/base-7.0.2/include/os/Darwin -I/Users/Newville/local/epics/base-7.0.2/include -I/Users/Newville/local/epics/base-7.0.2/include/compiler/clang -I/Users/Newville/local/epics/base-7.0.2/include/os/Darwin -I/Users/Newville/local/epics/base-7.0.2/include -I/opt/local/lib/perl5/5.26/darwin-thread-multi-2level/CORE -c Cap5.c c++ -o Cap5.bundle -bundle -undefined dynamic_lookup -L/Users/Newville/local/epics/base-7.0.2/lib/darwin-x86 -arch x86_64 Cap5.o -lca -lCom -lreadline -lm Installing loadable shared library /Users/Newville/local/epics/base-7.0.2/lib/perl/5.26.2/darwin-thread-multi-2level/Cap5.bundle which does correctly specifiy the include path for EXTERN.h as /opt/local/lib/perl5/5.26/darwin-thread-multi-2level/CORE. It seems like "/usr/bin/perl -V" is not reporting the absolute location of its include directories correctly, which might be part of the problem: ~> /usr/bin/perl -V .... @INC: /Library/Perl/5.18/darwin-thread-multi-2level /Library/Perl/5.18 /Network/Library/Perl/5.18/darwin-thread-multi-2level /Network/Library/Perl/5.18 /Library/Perl/Updates/5.18.2/darwin-thread-multi-2level /Library/Perl/Updates/5.18.2 /System/Library/Perl/5.18/darwin-thread-multi-2level /System/Library/Perl/5.18 /System/Library/Perl/Extras/5.18/darwin-thread-multi-2level /System/Library/Perl/Extras/5.18 . whereas EXTERN.h is actually in /Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX.sdk/System/Library/Perl/5.18/darwin-thread-multi-2level/CORE/EXTERN.h Hope that helps. --Matt
| ANJ, 23 Jan 2019 |
Home
News
About
Talk
Base
Modules
Extensions
