Hi Matt,
I don't know perl, but just to get through the build, I added a line to the file modules/ca/src/perl/Makefile in the EPICS 7.0.2 distribution as shown. With that, the build completes on the macOS Mojave platform. And as far as linking goes, the next release of spec will link with the 7.0 channel access libraries if the spec install configuration points to them.
I would think that the EPICS build should work with the stock perl distributed with macOS. If it is a bug in the way macOS packages perl, maybe the EPICS configuration tools should work around the bug, as macOS is a rather mainstream platform. It seems excessive to have to install a /usr/local version of perl just to fix the one "-I" flag.
- Gerry
*** Makefile 2019-01-23 10:08:06.000000000 -0500
--- Makefile.sav 2018-12-17 18:40:49.000000000 -0500
*** 53,60 ****
Cap5_SRCS = Cap5.xs
Cap5_LIBS = ca Com
! Cap5_INCLUDES = -I$(shell $(PERL) ../perlConfig.pl archlib)/CORE \
! -I/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX.sdk/System/Library/Perl/5.18/darwin-thread-multi-2level/CORE/
Cap5_CFLAGS = $(shell $(PERL) ../perlConfig.pl ccflags)
CLEANS += Cap5.c
--- 53,59 ----
Cap5_SRCS = Cap5.xs
Cap5_LIBS = ca Com
CLEANS += Cap5.c
Begin forwarded message:
> From: Matt Newville <[email protected]>
> Subject: Re: SPEC "can't get a big memory buffer" issue
> Date: January 18, 2019 at 12:57:45 PM EST
> To: Gerry Swislow <[email protected]>
> Cc: Mark Rivers <[email protected]>, "[email protected]" <[email protected]>, Joanne Stubbs <[email protected]>, Zhang Dongzhou <[email protected]>, Peter Eng <[email protected]>
> Hi Gerry,
> On Thu, Jan 17, 2019 at 9:32 AM Gerry Swislow <[email protected]> wrote:
> Hi Matt,
> My system does have the file
> /Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX.sdk/System/Library/Perl/5.18/darwin-thread-multi-2level/CORE/EXTERN.h
> But the folder containing the file is not included as a -I flag in the compile instruction. The closest directive is -I/System/Library/Perl/5.18/darwin-thread-multi-2level/CORE, which is a folder that only contains the file
> -rwxr-xr-x 1 root wheel 2505712 Nov 30 02:32 libperl.dylib*
> - Gerry
> Yes, it does look like a problem with building epics base on MacOS (at least with 10.14) with Apple-supplied Perl (5.18). I get the same error as you (perl's XS tool cannot find its EXTERN.h) trying to build both base-3.16.2 and base-7.0.2 with Apple-supplied Perl (/usr/bin/perl).
> I can build both base-3-16.2 and base-7.0.2 using perl (5.26) from MacPorts. Using that perl which got installed to /opt/local/bin/perl), the section of the build looks like this:
> /Applications/Xcode.app/Contents/Developer/usr/bin/make -C O.darwin-x86 -f ../Makefile TOP=../../.. \
> T_A=darwin-x86 install
> rm -f Cap5.c Cap5.c_new
> perl -CSD /opt/local/bin/xsubpp -typemap /opt/local/lib/perl5/5.26/ExtUtils/typemap ../Cap5.xs > Cap5.c_new && mv Cap5.c_new Cap5.c
> perl -CSD /Users/Newville/local/epics/base-7.0.2/bin/darwin-x86/mkmf.pl -m Cap5.d -I. -I../O.Common -I. -I. -I.. -I/Users/Newville/local/epics/base-7.0.2/include/compiler/clang -I/Users/Newville/local/epics/base-7.0.2/include/os/Darwin -I/Users/Newville/local/epics/base-7.0.2/include -I/Users/Newville/local/epics/base-7.0.2/include/compiler/clang -I/Users/Newville/local/epics/base-7.0.2/include/os/Darwin -I/Users/Newville/local/epics/base-7.0.2/include -I/opt/local/lib/perl5/5.26/darwin-thread-multi-2level/CORE Cap5.o Cap5.c
> cc -DUNIX -Ddarwin -O3 -g -Wall -fno-common -DPERL_DARWIN -mmacosx-version-min=10.13 -pipe -Os -fno-strict-aliasing -fstack-protector-strong -I/opt/local/include -DPERL_USE_SAFE_PUTENV -arch x86_64 -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I/Users/Newville/local/epics/base-7.0.2/include/compiler/clang -I/Users/Newville/local/epics/base-7.0.2/include/os/Darwin -I/Users/Newville/local/epics/base-7.0.2/include -I/Users/Newville/local/epics/base-7.0.2/include/compiler/clang -I/Users/Newville/local/epics/base-7.0.2/include/os/Darwin -I/Users/Newville/local/epics/base-7.0.2/include -I/opt/local/lib/perl5/5.26/darwin-thread-multi-2level/CORE -c Cap5.c
> c++ -o Cap5.bundle -bundle -undefined dynamic_lookup -L/Users/Newville/local/epics/base-7.0.2/lib/darwin-x86 -arch x86_64 Cap5.o -lca -lCom -lreadline -lm
> Installing loadable shared library /Users/Newville/local/epics/base-7.0.2/lib/perl/5.26.2/darwin-thread-multi-2level/Cap5.bundle
> which does correctly specifiy the include path for EXTERN.h as /opt/local/lib/perl5/5.26/darwin-thread-multi-2level/CORE.
> It seems like "/usr/bin/perl -V" is not reporting the absolute location of its include directories correctly, which might be part of the problem:
> ~> /usr/bin/perl -V
> @INC:
> /Library/Perl/5.18
> /Network/Library/Perl/5.18/darwin-thread-multi-2level
> /Library/Perl/Updates/5.18.2/darwin-thread-multi-2level
> /System/Library/Perl/Extras/5.18/darwin-thread-multi-2level
> whereas EXTERN.h is actually in /Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX.sdk/System/Library/Perl/5.18/darwin-thread-multi-2level/CORE/EXTERN.h
> Hope that helps.
> --Matt
- Re: SPEC "can't get a big memory buffer" issue Johnson, Andrew N. via Tech-talk
- Re: SPEC "can't get a big memory buffer" issue Heinz Junkes via Tech-talk
- Re: SPEC "can't get a big memory buffer" issue Mark Rivers via Tech-talk
- Re: SPEC "can't get a big memory buffer" issue Matt Newville via Tech-talk
- Re: SPEC "can't get a big memory buffer" issue Gerry Swislow via Tech-talk
Re: Simple alarm monitor Michael Davidsaver via Tech-talk
<2019>
2025
2026
<2019>
2025
2026
