1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: RE: Support for GBS MCA527
To: 'Hinko Kocevar' <[email protected]>
Date: Tue, 29 Jan 2019 17:30:18 +0000
Ø  My colleagues are also looking at some Canberra units. These are supported by the EPICS mca, right?
It supports some older Ethernet Canberra units like the 556 and DSA-2000.  It does not support the newer Canberra electronics.
The XIA electronics (xMAP, Mercury, FalconX) are supported.
Sent: Tuesday, January 29, 2019 10:23 AM
Cc: [email protected]
Subject: Re: Support for GBS MCA527
Hi Mark,
I got the same impression.
Hinko
Sent from my iPhone
On 29 Jan 2019, at 16:15, Mark Rivers <[email protected]> wrote:
Hi Hinko,
I looked at the User Manual for the MCS you were considering.  It appears the high-level software for it only runs on Windows and the Communication DLL is only available for Windows.  They do document the low-level firmware commands, but I think it would be a lot of work to write a driver for Linux based on these.
My software for the Amptek works on both Linux and Windows.
Sent: Tuesday, January 29, 2019 8:41 AM
Thanks Mark,
I’ll see what my team mates say about that one.
Cheers,
Hinko
Sent from my iPhone
On 29 Jan 2019, at 15:26, Mark Rivers <[email protected]> wrote:
Hi Hinko,
I don’t know of support for those.  If you are looking for a similar product with EPICS support the Amptek MCAs are supported.
http://amptek.com/products/px5-hpge_for_germanium_detectors/
From: [email protected] <[email protected]> On Behalf Of Hinko Kocevar via Tech-talk
Sent: Tuesday, January 29, 2019 4:14 AM
To: [email protected]
Subject: Support for GBS MCA527
Dear,
has anyone EPICS module for this MCA: GBS MCA527 , https://www.gbs-elektronik.de/posts/mca527-11.php ?
TIA,
Hinko
Support for GBS MCA527 Hinko Kocevar via Tech-talk
RE: Support for GBS MCA527 Mark Rivers via Tech-talk
Re: Support for GBS MCA527 Hinko Kocevar via Tech-talk
Prev: Re: calc record odd behavior Bruno Martins via Tech-talk
Next: Re: Symantec legacy certificate makes EPICS wiki untrusted Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: Re: Support for GBS MCA527 Hinko Kocevar via Tech-talk
Next: Keithley 3390 Arbitrary Waveform Generator gary.yendell--- via Tech-talk
ANJ, 29 Jan 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
