1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Point Grey GigE Blackfly conflict
From: Wayne Lewis via Tech-talk <[email protected]>
To: Nilson Pereira <[email protected]>
Date: Thu, 7 Feb 2019 11:15:13 +0100
Hi Nilson,
On Thu, Feb 07, 2019 at 10:17:19AM +0100, Nilson Pereira via Tech-talk wrote:
> I have 3 cameras (Point Grey GigE Blackfly) that I want to use
> simultaneously at a very low framerate (1fps) for BPM purposes.
> Each camera has its own IOC and they run perfectly one at a time.
> However, when running simultaneously, always 2 cameras conflict with
> each other and not necessary the same two cameras. During conflict, the
> IOC shows an error about frame inconsistency on both affected cameras. I
> have a gigabit network port on both switch and server, and the port is
> far from saturation.
> Does anyone have experience with GigE cameras and have seem this type of
> problem? Is this a protocol issue since it happens even with the
> original (Flycap2) software ?
> I appreciate any shared experience with problems with GigE cameras that
> could give a hint on why this is happening.
We have seen similar issues with Blackfly cameras. A few things we have
done to attempt to resolve it:
- put each camera on its own network port. We have a setup with two
cameras connected to a single host, where each camera network port is
configured as a different private network (e.g., 192.168.1.1/24 and
192.168.2.1/24). This helps segregate network traffic and avoid the
packet collisions and losses.
- ensure the camera and network port MTUs are set to 9000.
- if you have switch between the host and the cameras, check that it is
permitting Jumbo packets on the relevant ports.
- look at the FLIR knowledge base documents for configuring the network
receive and RX ring buffer sizes: http://www.ptgrey.com/KB/10016
After setting things up this way, we have two cameras running at 10 fps,
with only minimal 'Image consistency' errors.
Hope that helps.
Wayne
> Best,
> Nilson
> ________________________________
> Helmholtz-Zentrum Berlin für Materialien und Energie GmbH
> Mitglied der Hermann von Helmholtz-Gemeinschaft Deutscher Forschungszentren e.V.
> Aufsichtsrat: Vorsitzender Dr. Karl Eugen Huthmacher, stv. Vorsitzende Dr. Jutta Koch-Unterseher
> Geschäftsführung: Prof. Dr. Bernd Rech (kommissarisch), Thomas Frederking
> Sitz Berlin, AG Charlottenburg, 89 HRB 5583
> Postadresse:
> Hahn-Meitner-Platz 1
> D-14109 Berlin
  Wayne Lewis
  e: [email protected]
  w: http://ospreydcs.com
  p: +1 631 905 1964
Point Grey GigE Blackfly conflict Nilson Pereira via Tech-talk
Prev: Point Grey GigE Blackfly conflict Nilson Pereira via Tech-talk
Next: Re: Point Grey GigE Blackfly conflict Jörn Dreyer via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
ANJ, 07 Feb 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
