Subject: |
Re: Stream device - parsing array of pairs of floats |
Dirk Zimoch via Tech-talk <[email protected]> |
To: |
Date: |
Fri, 15 Feb 2019 11:09:14 +0100 |
The | in the regexp needs to be escaped:
in "%#/[.0-9]+\|//%f";
in "%#/\|[.0-9E+-]+//%f";
Without the escape it means "a number or an empty string". The empty
string matches always and is replaced by an empty string, not changing
the string at all and advancing by 0 bytes. Looking for the next match
starts the endless loop.
Need to fix that.
But otherwise it works. I got the two arrays.
If you want to do further processing on the arrays, be aware that the
"I/O Intr" record gets the value before the active one. So by the time
the active record processes its FLNK or triggers any monitors, the "I/O
Intr" record has already the corresponding value.
Dirk
On 15.02.19 10:58, Dirk Zimoch via Tech-talk wrote:
I tested it and it hung up my ioc. Seems I have a bug in regsub.
On 15.02.19 09:55, Dirk Zimoch via Tech-talk wrote:
Unfortunately StreamDevice cannot easily parse such interlaced arrays
at the moment.
Maybe the following works:
For the values:
Separator=",";
in "%#/[.0-9]+|//%f";
For the Timestamps:
Separator=",";
in "%#/|[.0-9E+-]+//%f";
%#/regexp/subs/ is the regular expression pre-processor, here removing
the "other" array from the input. Performance may be not so good and
scales like O(n²) with the array length because of all the copying
involved.
One of the records should be active having the 'out' command that
produces the reply. The other should be "I/O Intr" reading the time
stamps passively.
Not tested. Hope it works.
Dirk
On 14.02.19 18:35, Joao Afonso via Tech-talk wrote:
Hello,
I have a string returned by a device, representing an array where
each element is a pair <time, value>:
- each pair is separated by "|": <timestamp>|<value>
- each element of the array separated by ","
- all values are floats
- the timestamp increment may not be linear (that is why it needs to
be recorded)
Example
0.1000|0.1230000E+00,0.2000|0.4560000E+00,0.3000|0.7890000E+00, [...]
Is it possible to parse this using stream device (into two waveform
records)?
Or do I have to use something more powerful such as asynDriver?
I have seen several examples, but only with using simple type
elements, not like this.
As a followup, is it possible to do the inverse, merging two waveform
records into a string?
Thank you in advance,
Joao
CERN TE-EPC-CCS
- Stream device - parsing array of pairs of floats Joao Afonso via Tech-talk
- Re: Stream device - parsing array of pairs of floats Dirk Zimoch via Tech-talk
archiverAppliance access to Heinz Junkes via Tech-talk
<2019>
2025
2026
Re: Stream device - parsing array of pairs of floats Johnson, Andrew N. via Tech-talk
<2019>
2025
2026
ANJ, 15 Feb 2019 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
