1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: asynPortDriver callParamCallbacks(); not working but callParamCallbacks(0); working
From: Hugot Sebastien via Tech-talk <[email protected]>
Date: Mon, 18 Feb 2019 16:18:35 +0000
Hello,
I was relieved to find the solution of an asyn problem I had (behavior change from 4-26 to 4-27).
(https://epics.anl.gov/tech-talk/2015/msg01713.php)
Now, when I use the code,
   setParamStatus(param, ASYN_SUCCESS);  /* If it might previously have been an error code */
   setXXXParam(param, value);
   setParamStatus(param, ASYN_ERROR);  /* Or other error */
does not update the value of my parameter,
but with this version (using callParamCallbacks(0); instead of callParamCallbacks();)
the parameter value is updated.
Do you have any idea for such a behavior ?
I am using asyn4-32.
Sébastien.
Préservons notre environnement, n’imprimez ce mail que si nécessaire.
Preserve our environment, print this email only if necessary.
RE: asynPortDriver callParamCallbacks(); not working but callParamCallbacks(0); working Mark Rivers via Tech-talk
Prev: Re: How to detect AsynIPPort disconnect? Dirk Zimoch via Tech-talk
Next: RE: asynPortDriver callParamCallbacks(); not working but callParamCallbacks(0); working Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: Re: Problems with StreamDevice Dirk Zimoch via Tech-talk
ANJ, 19 Feb 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
