1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: RE: asynPortDriver callParamCallbacks(); not working but callParamCallbacks(0); working
To: 'Hugot Sebastien' <[email protected]>
Date: Mon, 18 Feb 2019 17:57:34 +0000
Hi Hugo,
If I understand what you are saying correctly, you see a different behavior when you call
vs
That does not make sense to me.  This is the code in asynPortDriver:
/** Calls callParamCallbacks(0, 0) i.e. with both list and asyn address. */
asynStatus asynPortDriver::callParamCallbacks()
    return this->callParamCallbacks(0, 0);
/** Calls callParamCallbacks(addr, addr) i.e. with list=addr, which is normal. */
asynStatus asynPortDriver::callParamCallbacks(int addr)
    return this->callParamCallbacks(addr, addr);
/** Calls paramList::callCallbacks(addr) for a specific parameter list.
  * \param[in] list The parameter list number.  Must be < maxAddr passed to asynPortDriver::asynPortDriver.
  * \param[in] addr The asyn address to be used in the callback.  Typically the same value as list. */
asynStatus asynPortDriver::callParamCallbacks(int list, int addr)
    return this->params[list]->callCallbacks(addr);
Note that:
callParamCallbacks simply calls callParamCallbacks(0,0)
callParamCallbacks(0) also simple calls callParamCallbacks(0,0)
Ultimately both call this->params[list]->callCallbacks(addr);
So I don’t see how they can behave differently.
Please send more evidence for your claim that they behave differently.
From: [email protected] <[email protected]> On Behalf Of Hugot Sebastien via Tech-talk
Sent: Monday, February 18, 2019 10:19 AM
To: [email protected]
Subject: asynPortDriver callParamCallbacks(); not working but callParamCallbacks(0); working
Hello,
I was relieved to find the solution of an asyn problem I had (behavior change from 4-26 to 4-27).
(https://epics.anl.gov/tech-talk/2015/msg01713.php)
Now, when I use the code,
   setParamStatus(param, ASYN_SUCCESS);  /* If it might previously have been an error code */
   setXXXParam(param, value);
   setParamStatus(param, ASYN_ERROR);  /* Or other error */
does not update the value of my parameter,
but with this version (using callParamCallbacks(0); instead of callParamCallbacks();)
the parameter value is updated.
Do you have any idea for such a behavior ?
I am using asyn4-32.
Sébastien.
Préservons notre environnement, n’imprimez ce mail que si nécessaire.
Preserve our environment, print this email only if necessary.
asynPortDriver callParamCallbacks(); not working but callParamCallbacks(0); working Hugot Sebastien via Tech-talk
Prev: asynPortDriver callParamCallbacks(); not working but callParamCallbacks(0); working Hugot Sebastien via Tech-talk
Next: RE: Problems with StreamDevice Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Next: Issue of PV callback of PyEpics Zhang, Tong via Tech-talk
ANJ, 18 Feb 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
