On 2/27/19 6:27 AM, will.rogers--- via
Tech-talk wrote:
I am looking at the exampleCPP repo for EPICS7.
When I run helloRPC I can use pvcall and p4p as a client successfully.
When I run pvDatabaseRPC, I can't use either, and I get the following message:
ChannelRPC not supported
HelloClient.cpp (helloRPC) and positionClient.cpp (pvDatabaseRPC) both use an RPCClient to communicate the server.
I think I don't understand fully. Can anyone clear this up for me?
Cheers,
Will
Let me answer helloRPC first.
This is a really simple example of using channelRPC.
It has a server that only implements channelRPC and nothing else, i.
e. it is not an IOC.
Thus channelGet, channelPut, and channelPutGet requests will all
fail.
It is started as follows:
mrk> pwd
/home/epicsv4/masterCPP/exampleCPP/helloRPC
mrk> bin/linux-x86_64/HelloService
pvAccess Server v6.1.0
It has a client that only issues a channelRPC request.
It is run via
mrk> pwd
mrk> bin/linux-x86_64/HelloClient
Hello anonymous
mrk>
pvDatabaseRPC is a much bigger example
Since you are running the example look at exampleCPP/documentation.
It has documantation about all the examples.
In particular look at exampleCPP.html and pvDatabaseRPC.html.
pvDatabaseRPC.html says
the following:
pvDatabaseRPC is an
example of a pvAccess server that has a PVRecord that supports
Channel RPC as well as the usual operations: Channel Get, Put
and Monitor and get introspection data.
It illustrates
synchronous and asynchronous RPC services, selecting services
based on the supplied pvRequest and using EPICS V4 to talk to an
existing object which has no knowledge of EPICS and call its
methods, so creating distributed objects.
It represents a device
which has a 2D position setpoint and readback as well as a
state. The device can be controlled through a client using RPC
commands to move through a sequence of points as well as
conventionally by putting to the setpoint.
Also have you seen
https://mrkraimer.github.io/website/developerGuide/developerGuide.html
I hope this help.
Marty Kraimer
- Basic PVAccess question will.rogers--- via Tech-talk
EPICS support for walter + bai Testing Machines tom.cobb--- via Tech-talk
<2019>
2025
2026
Re: Basic PVAccess question Marty Kraimer via Tech-talk
<2019>
2025
2026
ANJ, 01 Mar 2019 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
