1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Basic PVAccess question
From: Marty Kraimer via Tech-talk <[email protected]>
To: [email protected], Michael Davidsaver <[email protected]>
Date: Fri, 1 Mar 2019 06:44:50 -0500
On 2/27/19 6:27 AM, will.rogers--- via Tech-talk wrote:
I am looking at the exampleCPP repo for EPICS7.
When I run helloRPC I can use pvcall and p4p as a client successfully.
When I run pvDatabaseRPC, I can't use either, and I get the following message:
ChannelRPC not supported
HelloClient.cpp (helloRPC) and positionClient.cpp (pvDatabaseRPC) both use an RPCClient to communicate the server.
I think I don't understand fully. Can anyone clear this up for me?
Cheers,
Will
Will and I had some private messages and now I think I can give an explanation of what we found. pvcall appears to assume that both the client and server use normative type nturi.
https://github.com/epics-base/normativeTypesCPP/blob/master/src/pv/nturi.h
But neither exampleCPP/helloRPC or exampleCPP/pvDatabaseRPC use nturi.
Will did get helloRPC to work by making the following change to HelloService.cpp
-    epics::pvData::PVStringPtr nameField = pvArgument->getSubField<PVString>("personsname");
+    std::cout << "Argument " << pvArgument << "\n";
+    epics::pvData::PVStructurePtr queryField = pvArgument->getSubField<PVStructure>("query");
+    epics::pvData::PVStringPtr nameField = queryField->getSubField<PVString>("personsname");
Now I have some questions about pvcall and channelRPC.
Is pvcall meant to replace eget?
Are there plans for future enhancements to channelRPC?
If yes then what is the status?
Marty Kraimer
Re: Basic PVAccess question Michael Davidsaver via Tech-talk
Basic PVAccess question will.rogers--- via Tech-talk
Prev: Re: timeStamp in pvget request not populated when using display field in v3 IOC Jack Harper - UKRI STFC via Tech-talk
Next: Re: Fw: asynDriver - update record (timestamp), on no change Rod Nussbaumer via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Basic PVAccess question Marty Kraimer via Tech-talk
Next: Re: Basic PVAccess question Michael Davidsaver via Tech-talk
ANJ, 04 Mar 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
