1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: timeStamp in pvget request not populated when using display field in v3 IOC
From: Jack Harper - UKRI STFC via Tech-talk <[email protected]>
Date: Thu, 28 Feb 2019 14:43:21 +0000
I have been using pvget as well as the CPP API to attempt to set up a request for a v3 IOC that populates the timeStamp and display.units fields. For some reason, whenever i use anything from display, it stops timeStamp from being populated. I know the PVRequest is order-dependent, so I have tried moving the order of the fields around, but this doesn't help. I think this may be a bug, I am not sure if it affects V4 IOCs but i'd imagine someone would have flagged it up earlier if so.
Here is my output with a pvget request in channel access mode, you can see that the timestamp does not appear in the PV structure:
pvget SIMPLE:DOUBLE -r "value, alarm, timeStamp, display.units" -p ca
SIMPLE:DOUBLE
structure
    double value 1
    alarm_t alarm NO_ALARM NO_STATUS NO_ALARM
    structure display
        string units mm
Here is the output with the request without display (anything in display seems to prevent the timestamp being shown)
pvget SIMPLE:DOUBLE -r "value, alarm, timeStamp" -p ca
SIMPLE:DOUBLE
epics:nt/NTScalar:1.0
    double value 1
    time_t timeStamp 2019-02-28T14:39:06.177 0
Any help or verification that this may or may not be a bug would be appreciated.
Jack
[cid:7c128533-7c50-4c8a-b085-dbf0ac080bf5]
PNG image
Re: timeStamp in pvget request not populated when using display field in v3 IOC Johnson, Andrew N. via Tech-talk
Prev: EPICS support for walter + bai Testing Machines tom.cobb--- via Tech-talk
Next: asynDriver - update record (timestamp), on no change Joao Afonso via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Next: Re: timeStamp in pvget request not populated when using display field in v3 IOC Johnson, Andrew N. via Tech-talk
ANJ, 28 Feb 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
