1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: asynDriver - update record (timestamp), on no change
From: Joao Afonso via Tech-talk <[email protected]>
Date: Thu, 28 Feb 2019 17:16:39 +0000
Hello,
I have an asyn driver IOC that periodically receives new data, updates the parameters (and timestamps), and runs the callbacks for the "I/O Intr" records.
It has an extra thread that runs something like this:
while(1)
    int value = wait_for_data();
    setIntegerParam(dev_addr, param_id, value)
    updateTimeStamp();
    callParamCallbacks(dev_addr);
However, 'callParamCallbacks' will not update the record timestamp if the value received keeps being the same.
From what I understand, this is the intended behaviour of asynDriver - no updates if data is the same -, but I would like to know if there a way to enforce it (to update the record timestamp)?
One possible solution I think will work is to update the parameter with a random value first, to trigger the 'new data' flag, but it feels like an hack...
Example:
setIntegerParam(dev_addr, param_id, 0)
Thank you,
Joao Afonso
Prev: timeStamp in pvget request not populated when using display field in v3 IOC Jack Harper - UKRI STFC via Tech-talk
Next: Re: timeStamp in pvget request not populated when using display field in v3 IOC Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: timeStamp in pvget request not populated when using display field in v3 IOC Jack Harper - UKRI STFC via Tech-talk
Next: Fw: asynDriver - update record (timestamp), on no change Mark Rivers via Tech-talk
ANJ, 01 Mar 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
